78 Speedo Pronlem
Old Aug 18, 2005 | 09:36 PM
ChevyL82's Avatar
ChevyL82
Default 78 Speedo Pronlem
Changed transducer still no speedo. What to try next? Anybody out there have this problem before? It's a 78 pace car.
Old Aug 18, 2005 | 09:55 PM
big_G's Avatar
big_G
Did you check BOTH cables and the speedo driven gear in the trans. tail-shaft?
Old Aug 18, 2005 | 10:23 PM
canucbuck's Avatar
canucbuck
Old Aug 19, 2005 | 05:39 PM
ChevyL82's Avatar
ChevyL82
Found the problem. The plastic tip of the lower speedo cable was stripped down when transducer failed. Is there a fix for this? Local dealer said they used to replace plastic but can't get them anymore. Cable is fine otherwise. It is the 49" lower cable I just need the cable Housing is fine. Any Guru's out there. JB weld?
Old Aug 19, 2005 | 11:58 PM
big_G's Avatar
big_G
I think A/Zone has replacement tips and cables.
To 78 Speedo Pronlem
