touching up the pipes
Old Aug 19, 2005 | 06:42 PM
73'454folendore's Avatar
73'454folendore
Default touching up the pipes
While changing out the gas tank I took the time to wire brush the rear pipes. Took off all the rust which I know will return within months. Any help to finish them either paint them black or is there any other ideas to finish them off? Thanks http://i21.photobucket.com/albums/b2...dore/pipes.jpg
Old Aug 19, 2005 | 08:52 PM
dath's Avatar
dath
If it were me, I'd use flat black BBQ paint. It's also about the only paint I can think of that will hold up to the temperature for any length of time. . . Others may have other suggestions . . . I think there is some kind of aluminized (is that right?) spray you can also get to give them a shiny look if that's what you prefer.
-dath
Old Aug 19, 2005 | 09:04 PM
gator79's Avatar
gator79
flat black bbq paint here, just gives it a clean finished look
Old Aug 19, 2005 | 09:18 PM
fl_rider's Avatar
fl_rider
Default Bbq
I used to use the BBQ paint on my 4 into 1 for my old CB750.
If it started looking tacky a little steel wool and a fresh coat and they were like new again.
Old Aug 19, 2005 | 10:49 PM
Techno's Avatar
Techno
Might try that por rust proofing manifold stuff.
Old Aug 19, 2005 | 10:50 PM
carl a's Avatar
carl a
i tried paint 4 times, on my chambered exhausts,heat burned it every time, finally got them ceramic coated--have before photos on this cheesy free geocities website--http://www.geocities.com/carlclub2/--------------------------------------------------
To touching up the pipes
