Short or Long Water Pump?
Old Aug 22, 2005 | 09:26 AM
69396Chevy's Avatar
69396Chevy
Default Short or Long Water Pump?
Trying to determine if I have short or long water pump . . . kind of looks to be a long. I know on the Big Blocks whatever side the alternator is on tells what the pump is. This a 68 with what shoudl be a 69 350 in it, the alternator is on the drivers side. I want to order a new aluminum pump but need to know before I go order it to avoid having to pay retrun shipping costs if its not the correct one.
Chris
Old Aug 22, 2005 | 09:29 AM
big_G's Avatar
big_G
C-3 with small-block always use a short waterpump.
Old Aug 22, 2005 | 09:31 AM
mrtroutjedi's Avatar
mrtroutjedi
Old Aug 22, 2005 | 09:41 AM
69396Chevy's Avatar
69396Chevy
But I cant be sure if its a vette motor with vette accessories, but was told its a 69. Deck has been machined but the casting number shows a 69. Doesnt the alternator location have anything to so with it? What sides are your guys alternator on?
Old Aug 22, 2005 | 09:52 AM
big_G's Avatar
big_G
It doesn't matter. You must use a short pump.
Old Aug 22, 2005 | 10:21 AM
69396Chevy's Avatar
69396Chevy
Great . . . Thanks Big G!
Any suggestions on a good aluminum rad that will fit close to stock?
Old Aug 22, 2005 | 10:28 AM
big_G's Avatar
big_G
DeWitt and Be-Cool both make rads. with a good fit..
Old Aug 22, 2005 | 11:19 AM
OldSchool's Avatar
OldSchool
DeWitt's direct replacement..Fits like a glove... cha ching...
Steve
Old Aug 22, 2005 | 11:50 AM
68/70Vette's Avatar
68/70Vette
The short water pump measures 5.625 inches from the block to the top of the water pump pulley mount. The long water pump is 7.00 inches.
Check out:http://www.marchperf.com/csb_pulleys.html
Old Aug 22, 2005 | 12:25 PM
pws69's Avatar
pws69
Chris
There is a specific "Corvette" short pump - I believe it measures 5.8" (as opposed to the "standard" short pump at 5.625") and it has a 3/4" shaft.
Old Aug 22, 2005 | 03:35 PM
dmrodco's Avatar
dmrodco
He's right its neither ! its a corvette water pump. Had a friend bring his vette in and some one had put a short waterpump in and washers to make the pullys line up ! what a joke. he asked why the pully wobbled ! I handed him 3 bucks worth of washers. If you cannot do it right why bother.
Old Aug 23, 2005 | 07:02 AM
69396Chevy's Avatar
69396Chevy
OK, next question then. Who makes a specific "Corvette" water pump. Everything Ive seen just says short or long.
Old Aug 23, 2005 | 08:53 AM
76stingracer's Avatar
76stingracer
http://www.gmpartsdirect.com/
part number 14011012
Old Aug 26, 2005 | 12:41 PM
jackson's Avatar
jackson
GM, Stewart, Weiand, Edelbrock, etc ... dig into it & you'll find what you need.
Old Aug 26, 2005 | 01:31 PM
gerry72's Avatar
gerry72
Well, he's almost right. The 5.8" "Corvette" pump didn't come into being until 1971 and was used through the 1982 build. Prior to that(1970 and back), a regular "short" pump was used. Beyond the length difference, the pilot was 3/4" rather than the standard short pump's 5/8". Makes a difference in accessory drives in both alignment and fitting the pulley/fan on the pump.
Old Aug 26, 2005 | 01:48 PM
pws69's Avatar
pws69
Thanks for that!! I wasn't aware that the switch was that late - thought it was earlier in the 60's. Good to know.
To Short or Long Water Pump?
