Wiper Vacuum Questions
Old Aug 22, 2005 | 09:53 AM
72ls5fla's Avatar
72ls5fla
Default Wiper Vacuum Questions
Hey Guys ...
I have never had any problems with my wiper system .. this morning
after using my wipers several times, the door decided to not open.
It happens even when I use the override under the dash.
If I move the door manually to the open position and then move the switch under the dash, to close the door, it works fine. Just no upward movement.
Any suggestions ??
I'm figuring there are two vacuum relays, the one under the cowl and the other under the right side fender.
Which would you think is most likely the culprit ??
Any help is appreciated.
Bill
Old Aug 22, 2005 | 11:28 AM
kman8447's Avatar
kman8447
probably a seal on your actuator is bad. the wiper system is very similar to the headlight system.
Old Aug 22, 2005 | 12:02 PM
Boston!'s Avatar
Boston!
It's difficult to say which vacuum relay is giving you problems- the position sensing relay under the wiper door or the one under the fender. They can each be tested by pulling a vacuum (either with a vacuum pump or just by sucking on the hose) to the center port and plugging the outboard port to check for leaks in the seal. The relay under the fender is vauum actuated and you can feel/hear it switching when you suck on the smaller actuator port and then let it go- it will make a small clunking sound when you let the vacuum off.
These can be rebuilt by either following the instructions here:
http://209.183.231.72/corvette-101/vacuum.htm#relay
(as well as more detailed diagnostics), or I have actually put Orings around the plunger seal once inside the relay (you have to grind out the inside to make them thinner- PITA)
It's unlikely that it's your wiper door actuator giving you problems, since it uses the same diaphragm to move up as down.
-=Boston!=-
Old Aug 22, 2005 | 03:02 PM
72ls5fla's Avatar
72ls5fla
Thanks for the info.
I will try testing the one under the cowl first and move to the one under the fender next.
I'll post later to give ya'all a heads up.
Bill
Old Aug 22, 2005 | 05:39 PM
Techno's Avatar
Techno
Check the vacuum hose for opening- the fronter one. I had it come off on me one morning and lost the headlights too. It looked like it was on but wasn't.
Old Aug 22, 2005 | 08:22 PM
72ls5fla's Avatar
72ls5fla
Hey All ...
Well here it is...
The rubber boot that is inside of the wiper door canister - popped out.
I just happened to slide the dust boot back to inspect it and it was staring me in the face !
Bill
Old Aug 22, 2005 | 08:31 PM
cosmicvette's Avatar
cosmicvette
Originally Posted by 72ls5fla
Hey All ...
Well here it is...
Bill
Thats great news!
Well, my wiper door doesn't work, not even the override switch...which is a bummer...sounds like I have a vacuum leak.. Im going to replace the hoses with a hose kit from Doc Rebuild.
But can I ask something>> The wiper door canister - is that on the passenger side in the engine bay against the firewall?? the thing that you take off the rubber grommet so that you can manually override the wiper door?
Old Aug 22, 2005 | 09:12 PM
Edzred72's Avatar
Edzred72
Yes. Technically known as the wiper door actuator.
Eddie
Old Aug 22, 2005 | 09:29 PM
cosmicvette
Eddie
Thanks Eddie...thats what I thought it was called - Wiper Door Actuator. But I was hoping there was another thing that I missed and was holding out hope I would have an easy fix to my wiper door problem!
Im about to go and see if I can look up under the dash from underneath and see if there is a hose thats come off.
(theres a loud hissing sound from under the dash when I have the engine running).
To Wiper Vacuum Questions
