Welding exhuast
Old Aug 22, 2005 | 08:26 PM
76mike's Avatar
76mike
Default Welding exhuast
Anyone ever done welding on their exhaust before? Like themselves? I mean I have an arc welder, and the guys told me down at the muffler shop that they'd charge $250 for the labor I want them to do..... and $250 more to spend on other stuff would be nice. Can anyone tell me how hard this is/how to do it?
Old Aug 22, 2005 | 08:45 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
If your going to weld it yourself use a MIG welder with gas. Tack weld it together under the car and finish welding it on the floor so you can get full 360 deg. welds. Also, if you use overlapping joints, instead of butt welds, it makes the job alot easier.
Old Aug 22, 2005 | 09:01 PM
72 RAY's Avatar
72 RAY
Mig with gas and .023 wire for butt welds.
Old Aug 22, 2005 | 09:09 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
It must be mig welded, even better is tig welded using stainless pipes. Also have a good look for any gas line leaks, no matter how minor, keep a fire X close by when tacking. Any grease, oil or undercoating underneath may catch fire.
Old Aug 22, 2005 | 09:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
That's exactly why I bought my flux core welder, the local shops charge an arm and a leg for exhaust work....
Flux core welds are ugly - you'll need to grind the welds clean after you're done welding. Depending on how often you weld it's up to you if you want a MIG/gas setup or just a cheap flux core welder. Flux core welders don't require shielding gas (it's in the wire), these are only around $150
Old Aug 22, 2005 | 09:38 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Old school Acetylene torch
Old Aug 22, 2005 | 09:51 PM
76mike's Avatar
76mike
Is my welder a flux-core? It has the coating on the outside... I think that the lowest it will go is like 65 amps, you prolly need less than that to weld the exhuast hu.
Old Aug 22, 2005 | 10:11 PM
72 RAY's Avatar
72 RAY
I wouldn't try it with an Arc welder unless your REALLY GOOD and you use a small guage electrode.
Old Aug 22, 2005 | 10:22 PM
76mike's Avatar
76mike
I'm not bad...... I did most of the welding for my grandfather's tractor that he built... i'll practice on some tubing first. But to save $250? It will be worth it.
Old Aug 22, 2005 | 10:26 PM
72 RAY's Avatar
72 RAY
If it's a fillet weld you should be OK but a butt weld will take some practice to get the settings right. Practicing on some tubing is a great idea.
Good Luck!
As far as being worth it. How much is your time worth?
Justa thought!
lowbuck72's Avatar
lowbuck72
Forget about using an arc welder for exhaust, you'll make yourself nuts. Arcwelders are good for welding large pieces of metal together, anything less than a 1/8 6013 rod isn't worth the aggravation of the rod sticking. I have been using my trusty .035 fluxcore wire feed for years, and I have no trouble laying down a nice bead. I welded up my own exhaust on my '72, headers, flowmasters and an H pipe. I left one slip joint on each pipe just in front of the H pipe in front of the rear axle for possible removal later. Even put a unboltable flange on the H pipe. Practice on scrap pipe first.
Old Aug 22, 2005 | 10:30 PM
76mike's Avatar
76mike
Yeah I will be sure to practice. How hard/how much would it cost to put in a whole H-pipe system with flowmasters and dual cats as an upgrade to my current 2-1-2 stock '76 system?
Old Aug 22, 2005 | 10:38 PM
72 RAY's Avatar
72 RAY
Time and Material ( T & M ) Baby!.
Price out the stuff you want and figure in the fab time. Shop rates or your time. Not to bad if you have a plan and the parts. If you do it, be prepared to spend a lot of time on the creeper. If you buy the stuff you want and take it to an exhaust shop they can bend the conectors and weld it up in no time.
As far as the parts are concerned there a million threads on this subject. Take your pick.
Have fun!
Old Aug 22, 2005 | 11:34 PM
steves_77vette's Avatar
steves_77vette
For me the tougher part was the right bends in the right places. That needs a mandrel bender to do it right.
Old Aug 23, 2005 | 12:37 AM
RHD '68 L89's Avatar
RHD '68 L89
I bought a bunch of Mandrel bends and used my arc welder to tack and then weld the extractors. Can be done but Mig and Tig are easier. If you do decide to Arc weld practice, practice, practice before starting. Thin tube butt welded is probably the hardest to do.
Had a professional do the rest of the system and wasn't impressed with the quality of the work. Should have done it myself.
Old Aug 23, 2005 | 01:03 AM
76mike's Avatar
76mike
Well assuming I could get ahold of a MIG welder (I have some connections), and I used the same exhaust tubing, could I pretty easily do the cat and the mufflers?
Old Aug 23, 2005 | 01:14 AM
ram82fire's Avatar
ram82fire
I run the wire downhand vertical with .030 wire for all my butt welds .Just carefully fit the joints and make sure the metal is clean . You can make great passes with no burn through . Just practice a bit with some scrap to get the feed and heat right .
Geo
Old Aug 23, 2005 | 10:49 AM
mrtroutjedi's Avatar
mrtroutjedi
I arc welded mine but I used to be a pipefitter and a welder it was easy ya just need the right rod and the right amps an the machine.
Old Aug 23, 2005 | 12:56 PM
Brown78's Avatar
Brown78
I'm old school too. Give me a acetlene torch With a #2 head and a bunch of coat hangers
To Welding exhuast
