Rear Leaf Spring
Old Aug 23, 2005 | 10:05 AM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Default Rear Leaf Spring
Hi, I was wondering if my leaf spring (7 leaf) needs to be replaced as the car is low on the left rear. All the shocks and the rubber for the leaf springs have been replaced.From what I have measured (one half inch) it is not much but is noticable. Thankswww.vettepics.com/images/70/1970_silver_062805_thumb.jpg
Old Aug 23, 2005 | 10:17 AM
gearheadz's Avatar
gearheadz
It's not uncommon for C3s, to be slightly uneven from one side to the other. Unless the spring is severely fatigued, there is no reason to replace it.
You can usually even up the sides by adjusting the spring bolts at each end of the spring. Raise the height by tightening the retaining nut and lower it by loosening it.
Mark
Old Aug 23, 2005 | 11:13 AM
JIMS1970VETTE
Finally learned how to put a picture in the forum.
Old Aug 23, 2005 | 11:16 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
get a composite spring. They don't "wear" down... If you keep the exhaust far enough away from the spring, they'll live forever...
Old Aug 23, 2005 | 01:40 PM
vettfixr's Avatar
vettfixr
Mine is crooked too. I've seen a lot of vettes that didn't sit just right. I wouldn't worry about it.
Old Aug 23, 2005 | 03:11 PM
flynhi's Avatar
flynhi
Generally sags on the left due to the driver and battery on the left and many fewer miles with passenger. If it bothers you, swap ends of the steel spring.
Old Aug 23, 2005 | 03:47 PM
Harleydude51's Avatar
Harleydude51
Interestingly, I have a similar issue. But my rear spring and all bushings are new. What i did find out (since my left rear is higher than my right rear) is my right front spring sags more than my left front. This will cause the left rear to sit higher. Now I'm ordering a set of front springs!
Old Aug 26, 2005 | 10:38 PM
JIMS1970VETTE
Well I am going to turn ends on the spring first and see what happens.
Old Aug 27, 2005 | 08:55 AM
rihwoods's Avatar
rihwoods
Suggest you base dimension checks to frame,rather than body...there is a variance on how body was fit at factory...I still have my original 7 leaf...only 1/4" difference...
Old Aug 27, 2005 | 02:51 PM
JIMS1970VETTE
Well got the spring swapped along with some clean-up underneath and painting, heres some pics. http://img234.imageshack.us/img234/8...closeup3iu.jpg http://img234.imageshack.us/img234/4...gbefore0or.jpg http://img234.imageshack.us/img234/8...ngafter7vx.jpg
Old Aug 27, 2005 | 03:00 PM
rihwoods's Avatar
rihwoods
I can see a slight body lean to drivers side...try measuring from floor to frame just forward of rear wheels both sides..just curious what you get...
Rich
To Rear Leaf Spring
