Idle problems w/ low mileage '81
One detail: when he got the car, the MAP sensor was disconnected and the the port on the base of the carb was capped. He had the MAP sensor replaced with a new GM part and hooked back up. But even if you unhook the MAP sensor and re-cap the port on the carb now, you still have the same idle problem. I wonder why the MAP sensor was being by passed? When it was not connected, the 'check engine' light would light at idle. As soon as you were underway, it would go off.
I went this route with my 81 and did a serious overhaul on the engine and I now have the power that I want. I know that there's a port under the ash tray. Where would you go to have someone check the codes? (Other than a Chevy dealership!)
1st it'll start flashing code 12, that's flash one time slight pause then it'll flash 2 times. I think it does this 3 times then it'll start flashing other codes if there stored in the ECM. I think each code flashes 3 times then on to the next, when done it'll start flashing code 12 again.
If you don't get a 12 the ECM is probably fried, or something else is wrong.
Good luck!
The idle problem could be due to the car standing and the fuel drying out. I've recently had to strip a carb that's stood for 2 years with unleaded fuel in it & the fuel dried into something like vaseline & had blocked up some jets, so there could be crud in the carb causing this. My '81 has occasionally cut out after starting from warm but I think that's because I've set the idle quite low. If I slightly increase the rpms for about 10secs after starting from warm then it'll idle OK. If I start it from cold & blip the throttle before it's fully warmed up (to get the choke off) then it will also sometimes cut out. This is just as you've described, but mine does it because I've dropped the idle speed down below what it should be. When it's warmed up I get a nice slow, regular idle & I like that
If I set it to the speed stated on the under-hood label then it doesn't cut out at all. There's a screw to manually adjust the idle speed on the carb. Again, I can't remember where it is as it's been a while since I touched it!! I think it's on the d.side. If you look at the throttle linkage you should see a screw (with the head facing to the front of the car) which adjusts where the linkage sits in the idle position. Turn this in slightly to bump up the idle speed a bit (remembering where the screw was set to in case you want to go back to original - or I'm feeding you a bunch of BS & you're looking at the wrong screw!). It shouldn't take much adjustment to stop the problem if it's due to the idle being to low (like I've done). Make sure that the engine is up to running temp & that the aircon is OFF when doing this. There should be a solenoid mounted to the front of the carb which pushes a "bolt" out onto the throttle arm when the A/C is on. This should bump up the idle speed about 100rpm to prevent the engine cutting out at idle when the A/C is on.Something else to check is for wear in the throttle spindle. The way the Q-jet works puts a lot of wear on the throttle shaft where it goes through the soft metal of the carb body. With the return spring & operating cable both pulling on the d.side end of the shaft, wear can rapidly occur. This then lets the throttle shaft move about in the body, with more movement on the d.side. The primaries may not close properly (giving a slightly different idle speed each time you shut the throttle) & there'll be a slight air leak due to it. So grap the throttle spindle by the bracket on the end & see how much wear there is in the pivot through the carb body. If there's a lot of wear (mine was in a fore & aft direction) it can be cured by fitting some brass bushes in the carb. There's kits to do this yourself, or somebody can to it for you (assuming that there is any wear). It's an easy job, but a lot of really ****ly problems disappear once done.
So, I'd check for error codes, increase the rpms slightly, check for excessive wear in the throttle shaft (this isn't a problem with just the electronic carbs) & see what happens. I'd also check the float level & clean the filter before even thinking of stripping the carb down.
I wouldn't suspect the computer or settings yet as there could just be some dirt in the idle circuits, or a small vacuum leak.
Haven't a clue about the cruise control as mine has been removed, but it does sound suspiciously like a small vacuum leak. Are all the emissions systems still connected & working? Two small vacuum leaks I found on mine were real b'stards to find. One was the purge cannister which had a very small leak from one of the valves. the other was a solenoid thing for the EGR system. There was a 90 deg plastic vacuum connector that connected to the underside of it & somebody had pulled it off. Both those small vacuum leaks caused me lots of flashing check engine lights, although the car felt OK to drive. What I did was to follow the vacuum diagrams, work out what was what & then disconnect each system from the carb in turn, plugging the hole at the carb & seeing if there was an improvement. The only system I wouldn't advise doing that on is the vacuum to the brake booster!
Unplugged MAP sensor is an uknown. Bubba does some strange things to these cars
Good luck
Good luck
Yes, the car is 'all there' and completely original. This's why he'd like to keep it that way, as you rarely see these C3's so complete and NCRS original today. This is what I needed & I'll (we'll) check out all of these little details. As I've said, once the car reaches operating temp, it runs like a dream; it's only at start up are there problems. I already had tweaked the throttle linkage adjustment screw and bumped up the idle by 500 rpm, but that wasn't the problem. I still suspect a problem in the idle circuit of the carb and believe that a re-build would be in order, especially taking into consideration how long this car sat with it only having 35,000 on the clock. The previous owner of the car rarely drove it & I'm sure that fuel stabilizer wasn't used! I'd bet $$ that there's some varnish buildup somewhere in the carb. Also a small vaccum leak is possible & that needs to be checked as well, although I did the 'starting fliud' check (spraying around the carb & vacuum lines) to see if the RPMs increased which would indicate a vacuum leak. There was no change trying this method. The car is very driveable but it's annoying to have it shut off 3 or 4 times before it will hold a stable idle!
