Too many variables and problems w/ motor - help!
Now I'm back to doing break-in #2 with a new cam and a re-built but untuned carb. I started this afternoon to do the break-in and first time out had a flame thrower. In addition I could WOT the thing but only get to 2200 rpm (that's all before I noticed the flame thrower effects). So, only about 3 minutes of break-in and then I had to turn it off or else burn my car up!
I did two things: advanced the timing about 6 degress and also checked the carb float level. I noticed that the air-horn was a little saturated with gas was why I looked at the float. A flame thrower can come from either re-tarded timing or a really rich mixture is why I did both. I checked the float level and it seemed to be too high. I had gas in the bowl up to about 3/4 of the way in the bowl. So I lowered the float to about 0.5" measured from the back of the float to the top of the bowl. Fire it up again and now the flame thrower is gone but when I get it to 2200rpm to keep it there for the remaining 20 minutes of break-in I get a miss, a little blow back out the carb and occassionally a little flame. I can recover it by letting off the throttle and then bring it back and then about 2 seconds of 2200 rpm it does it again. So, it's not a one off problem it keeps repeating. I stopped one more time, retarded the timing about half way in between, I'm guessing at 12* BTDC, and repeat with the same results. The vac advance is disconnected.
Where to look next for this situation?
Dep
Fouled plugs can, of course, be from running too rich. 12* seems to be a pretty hefty timing adjustment to me, so I would turn to the carb.
Hope this gives you some ideas. Let me know how it goes.
-Ben
It's for those reasons that I'm going down the carb route. I did clean and check the plug gap. All ok. 12* may be a little too far advanced but it shouldn't make the car do all this weirdness at 2200 rpm and blowing gas out the air horn like it's someone is poring it downt the throat. I've seen carb back fires before and generally speaking you see the mist but you don't get wet. I literally have drops of gas flying back. Gasoline is not one my preferred colognes.
Brett
* Got the new Holley 4160 installed. That was a lot more work than I expected because of the need to setup the linkages with an Edelbrock linkage kit. Got everything on and ok, took about 2 hours of adjustments.
* Checked the timing again. Set the timing to 12 BTDC just as before with the XE268H cam before it wiped.
* Start her up and it's running like poop. Can't even get it to 2000 rpm without serious blowback through the carb.
* Pull out a different set of plug wires and put those on. No difference, still poop.
* Pull the plugs themselves since they were fouled and cleaned and put in new Autolite plugs. No difference, still poop.
So at this point I'm pulling my hair out, beating on the car and then I thought to see how the main BAT going into the distributor looked. With just the key engaged I was getting a decent 12V at the clip going into the dist. So, here's what I did:
* I was able to jam the negative lead to my meter into the throttle bracket and wedge the positive lead into the underside of the BAT clip to the dis and then set the meter so I could see it through the windshield.
* Try firing it up and it's running like poop for about 2 seconds, the meter is twitching around from 8V to 12V and all over the place, and then all of a sudden smooth as silk running at 2500 rpm. The meter is showing a solid 14V and it's looking good.
* Running for about 2 minutes and I'm smelling the headers getting too hot again (you know you're getting too good when you can tell a problem by it's smell!
). Shut it off quickly and look underneath and the headers are a dull red at the collector. I let that cool off and advance the dist to 16 BTDC.* Hop in and start it up again. Now it's running right out of the gate and up at 2200 rpm almost instantly. Let that run for 5 minutes. Shut it down quickly and look at the headers. The glow is gone and the headers are not overheating dramatically.
* Hop back in and it starts up just fine again and I run it to 2200 rpm and vary it every few minutes from 2000-2500 rpm for the next 15 minutes. Everything is solid. Water temp good, oil pressure good, the meter showing a solid 14V on the BAT terminal to the dist.
* At the end I run it up to 2500 rpm, 3000 rpm each for 1 minute and then back down in 500 rpm increments to 1500 rpm each for 1 minute. THis is procedure in the Lunati install instructions.
Shut her down and everything looks good. What a freakin' mess though getting all those issues untangled. Looks like a compounded problem of too rich carb, electrical problems, fouled plugs, and 4* BTDC more advance. But it's worth it now that I have the motor running. What a week!
