Grounding braided plug wires - distributor end
Old Aug 26, 2005 | 10:40 AM
ifky 71's Avatar
ifky 71
Default Grounding braided plug wires - distributor end
Where do I ground braided spark plug wires on the distributor end on a 71 LS5 / 454 / BB?
Thanks.
Ifky
Old Aug 26, 2005 | 10:49 AM
big_G's Avatar
big_G
The wire/shield support brackets on either side of the intake manifold have studs (10/24, I think) that you stack the 4 grounds onto. Then put a nut on to secure them.
Old Aug 26, 2005 | 06:09 PM
ifky 71's Avatar
ifky 71
Hmm. No studs on my manifold and no shield of course. Thanks for the info. This NOM I have is starting to haunt me. I thought the manifold was orrigional. I guess I really need to get into the numbers and decode what I have.
Can anyone reccomend any good on or off line databases for decoding engine components. I guess I'll start with the manifold.
Thanks again.
Ifky
Old Aug 26, 2005 | 06:12 PM
big_G's Avatar
big_G
If you have an assembly manual, it shows how the ignition shielding and wire supports are bolted to the intake. All the parts are available thru mail-order suppliers.
Old Aug 26, 2005 | 08:33 PM
RHD '68 L89's Avatar
RHD '68 L89
It should be similar to the 68/9 BB setup. There are two brackets which mount on the rear manifold bolts. the shielding is mounted to these brackets. the plug leads (and braids) enter the shielding through a four way grommet. Inside the shielding, and it may be on the bracket, is a stud which the braids slide over and are held by a nut. the braids have a lug crimped on them at both ends. one end is held by the rocker cover bolts and the other is in the shielding as described.
Old Aug 26, 2005 | 09:11 PM
rponfick's Avatar
rponfick
I just went through this on my 69, L-71, but decided to stay with regular rubber sparkplug wires. After getting all the braided wires inside the shielding and trying to get them seated on the grounding stud, I decided they were much too close to the coil terminals. I didn't want to risk shorting out my coil and TI, and get stranded. It didn't look too safe to me.
Just my 2 cents.
To Grounding braided plug wires - distributor end
