Time to replace control arm bushings???
Old Aug 26, 2005 | 12:58 PM
71SoCal's Avatar
71SoCal
Default Time to replace control arm bushings???
I just got my Steeroids kit. I've removed my old steering components, but now I'm wondering if I should go ahead and replace all the control arm bushings while the car is apart, and since I've got to get an alignment anyway.
Best that I can tell, they look a little worn. It looks like a simple job. What specialty tools are needed? A spring compressor for sure.
Are auto parts store bushings good enough? Should I put the shims back afterwards, or just let the alignment shop figure it out?
Thanks for any input...
Old Aug 26, 2005 | 01:22 PM
Tom454's Avatar
Tom454
If you decide to do the work...
There are many ways to skin a cat, and many ways to remove/replace the bushings... no shortage of preferred methodology here on this forum... but...
The A-Frames can be easily bent if you (or a shop) do a sloppy job.
The A-Frames should be supported between the ears when assembling to avoid bending the ears. The cross shaft should rotate freely after you're done. Otherwise you bent the A-Frames.
The original tool for the job was made by Kent-Moore, but you can make your own tool, or rig something up. Objective is to avoid bending the ears.
The tool is shown in the service manual.
I have the manual, and the original tool.
I have had to toss customers A-Frames in the trash because they were so chewed up & bent by previous mechanics (aka Bubba) that they were not serviceable. Pay yer money, take yer chances.
Old Aug 26, 2005 | 02:03 PM
NHvette's Avatar
NHvette
They get easier to do ... about the third set you remove/install.
I no longer use a press ... the job can be done with
hand tools, air hammer (chisel), propane torch, and practice.
I have fabricated some supports (between the ears) from
1 1/2" iron pipe - sliced down the middle and ground to fit tight.
Look for Lars' front end rebuild paper ... good techniques.
http://www.corvettefaq.com/lars.asp
If you have time, send 'em to a reputable rebuilder ... Van Steel, Bairs, etc.
If you use new aftermarket front springs - no compressor is required.
They come out easily - but getting the stock springs back in can be a
battle without a compressor.
Old Aug 26, 2005 | 06:15 PM
Rockn-Roll's Avatar
Rockn-Roll
I'm doing my suspension during the clean up of my engine compartment...yeah, while the compartment is empty do the control arms. The bushings are a bit tricky, but JCWhitney has a nice tool for the job:
http://www.jcwhitney.com/autoparts/P...003587/c-10101
The hard part is getting those rivets out! I'm having to cut the ball joints off because after cutting the head off of the rivet and trying to tap it out just isn't working...they are in there nice and solid. I picked up a diamond cut-off disk and arbor conversion for my drill which is working great...takes awhile to cut it off though.
You can also get a spring compressor from JCWhitney.
Old Aug 26, 2005 | 09:38 PM
norvalwilhelm's Avatar
norvalwilhelm
I like the poly bushings and do not use a press to install them. I use a flapper wheel and clean the bores really well, grease the metal sleeve and using mild pressure push them in basically by hand. Rubber requires a press.
Remember the bushings are not to be shock absorbers. They are to be bushings that allow the A arms to move up and down. If the bushing assembly is so tight the bolts can only be tightened when the car is on the ground sitting level that means the bushings are being distorted and every time the car goes over a bump the bushings are being twisted.
I feel when installed and the cross shaft is clamped in the vise the A arm should be free to move. I torque the end bolts in the vise and make sure the arm still moves freely up and down.
Rubber is completely different / installation/ tightening and feel.
Go poly.
Old Aug 27, 2005 | 03:34 AM
MoneyPit's Avatar
MoneyPit
It has been a couple of years since I did mine. However, you do not need a press, as mentioned above. There is a good article on this subject in the tech section of the forum. You can download the article, and put it right there beside you for the work. Like I said, it has been a few years since I did this, but as I remember I took an air chisel, and just worked around the lip of the old bushing until I could get a good "bite" with the chisel, then the bushing came out easily. The torch method works, but it is dirty, and smelly. I would recommend using the air chisel. On the install, i think I just cleaned the bore, pushed the bushing as far in as I could be hand, and then re-inserted the crossbar. With the cross bar in place, I replaced the end-caps, and used a longer bolt to "draw" the bushing into place. Anyhow, that is what I remember, but could be wrong.
Old Aug 27, 2005 | 11:55 AM
Todbo's Avatar
Todbo
it takes BFH , and a big swing
Old Aug 27, 2005 | 08:01 PM
norvalwilhelm
Technic beats a BFH every time. I will not use force. Force destroys more then it fixes. If you need a bigger hammer you technic is wrong.
Old Aug 27, 2005 | 08:30 PM
72LS1Vette's Avatar
72LS1Vette
My upper ball joints came out easily after grinding off the rivet heads. Make sure you take out the bolts for the lower joints. Sometimes there is so much crud down there that it's hard to tell that the ball joints are held in by bolts.
Rick B.
Old Aug 27, 2005 | 10:41 PM
Rockn-Roll's Avatar
Rockn-Roll
Rick B.
Actually, my lower control arm rivets did pop right out, it's the upper that I'm working on now and has me cussing and thinking of getting some rebuilt units.
To Time to replace control arm bushings???
