Cruise-In IV Veteran
Cruise-In V Veteran
The goal
OK here is exactly what I am trying to achieve right now
365 +/- 5
the requirements
8.25:1 compression(8.7:1 is also a possibility)
Hydraulic roller cam
aluminum cylinderheads
dual plane intake
shorty headers of a 1.675 diameter
What I am leaning towards
AFR 180 heads
crane HR-276-2S-12 IG cam with 214/222 at .050 and .488/.509 lift
Weiand 8120 dual plane intake(clearence issues later down the line)
holley 750cfm 4150 carb
sanderson headers
365 +/- 5
the requirements
dual plane intake
AFR 180 heads
sanderson headers
Crane calls for that cam to be used with 8.75 - 10.5 CR. If you want to run less, you should call Crane's tech dept. for advice.
wasting your money on that nice of a head. forced induction reduces the value of great heads. about 365 hp on 8.5 or 8.7 compression, that's a tough formula to complete.
Cruise-In V Veteran
They arent that much more expensive than some competing aluminum heads
