header temps
Old Aug 28, 2005 | 12:33 AM
gator79's Avatar
gator79
Default header temps
got a new IR temp gun and was checking around, there is a big difference in my header temps at each cylinder anywhere from 237 to 450 degrees. the cylinders at the rear of the engine seem to be hotter. I know all the tubes make different bends could this be why? is this normal?
Old Aug 28, 2005 | 12:47 AM
Retro78's Avatar
Retro78
I found that the bends do make a big difference, shoot on a consitent place on each cylinder right near the flange. The rear cylinders are hotter on mine by about 30.
Old Aug 28, 2005 | 02:47 AM
Carl Granquist's Avatar
Carl Granquist
Default Hot
My headers show a range of between the high four hundreds and the low five hundreds (degrees farenheit) measured at about one inch back from the flange. That's the easiest place for me to hit with the red light spot on all eight pipes. And that's after about a half hour run at city street speeds on a sumer afternoon (seventies to eighties ambient). I know there's a huge amount of heat building in there and I'm amazed my plug wires haven't melted yet. Back home in the garage I generally lift the hood for a couple of hours to help dump the heat. I paid a lot for my new Delco ignition wiring.
Old Aug 28, 2005 | 03:42 AM
Patience's Avatar
Patience
Yup, the front two header tubes (one on each side) is about 30-70 degrees cooler than the back ones. I'm assuming airflow from the fan contributes to this phenomenon.
Old Aug 28, 2005 | 06:39 PM
terry82's Avatar
terry82
i love my ir gun .you can check brake calibers and for heat leaks coming thru the firewall ,have also checked under the dash for ac air leaks
Old Aug 28, 2005 | 06:50 PM
guvnerwl's Avatar
guvnerwl
St. Jude Contributor
How about a brand name on your IR guns? The ones you like - and the ones you don't!
TIA
Old Aug 28, 2005 | 06:57 PM
Patience's Avatar
Patience
I bought mine from Costco for $65. Brand name is Alltrade.
Old Aug 28, 2005 | 07:01 PM
gator79's Avatar
gator79
mine is a rayteck 49.00 neat tool to have, header temps up to 450 but both mufflers at 131 sure cools alot as it gets father back
Old Aug 28, 2005 | 07:12 PM
terry82's Avatar
terry82
i got mine at harbor freight on sale $49.00 one year warranty .liked it better than the one from sears ,just had a better handle .con tech the maker
To header temps
