T-Tops won't shut
Old Aug 28, 2005 | 06:08 PM
Vmaxkid's Avatar
Vmaxkid
Default T-Tops won't shut
I just got my newly purchased 78 Pace Car home and bought a set of t-top weatherstripping from Carlisle. I stripped off the old weatherstripping and installed the new ones but now I can't get the t-tops to shut. Is this common? What do I do? It appears that maybe due to the flattened original stripping the t-tops have flattened out in length. I actually need to bend the t-tops considerably to make them fit. I have tried a heat gun to heat it up and have been bending the hell out of them but can't get them to shut. Any solutions?
Bryan
Old Aug 28, 2005 | 06:40 PM
Vmaxkid's Avatar
Vmaxkid
Now I am able to get one t-top shut but the glass panel at the windshield header sticks pretty far up, like a 1/2 inch after the latch is closed.
Old Aug 28, 2005 | 07:00 PM
Duke94's Avatar
Duke94
I had the same problem when I replaced the weatherstrip. Ended up lubing the heck out of the weatherstrip and windshield frame. I eventually got them latched. After leaving them latched for a couple of weeks, I can get them on/off easy. I used silicone spray but I thinnk "Krytox" is much better but cost big $$$
Old Aug 29, 2005 | 08:00 AM
vettfixr's Avatar
vettfixr
The latches and pins for the tops may have to be shimmed to allow for the thicker weatherstrip. I don't have glass tops so this may not apply to you but the pins that go into the center bar can be shimmed using specific shims that you can get from any supplier. The latches usually can be adjusted by turning the adjusting bolts. It's really a trial and fit procedure but with a little tinkering you can get the new weatherstrip to fit correctly.
Old Aug 29, 2005 | 01:33 PM
Biker's Avatar
Biker
vettfixr is correct. After replacing the T-top seals on my '81, I simply adjusted the latch and they fit fine.
Old Aug 29, 2005 | 08:28 PM
Vmaxkid's Avatar
Vmaxkid
Thanks for the replies. I was able to get them both on and latched down but they are real tight. I had to adjust the latch a bit but they are on. I am only afraid that going down the road the body will flex and the panels pop out.
To T-Tops won't shut
