whistle fm clutch
Old Aug 29, 2005 | 07:25 AM
panic's Avatar
panic
Default whistle fm clutch
hi, when the car is still cold i listen like a sort of whistle coming from the clutch when releasing the pedal in first gear, when the gear is in it stops, also when the engine/clitch is warm there is nothing. my application is a vette '77 with 570hp brand new 406 engine and the clutch has a McLeod new 11' steel flywheel, 11' pressure plate, release bearing and heavy duty clutch disk...the car is used on street with white gloves (for the moment ), is it going on something wrong there? thanks
Old Aug 29, 2005 | 10:01 AM
jbroughton's Avatar
jbroughton
Bad release bearing maybe?
