Greaseable U-Joints
Old Aug 29, 2005 | 11:48 PM
Federot's Avatar
Federot
Default Greaseable U-Joints
Is it ok to use High Temp Grease with greasable u-joints or should I stick with Lithium Grease (not the white)?
Also, should they be pre-packed before assembling them in the half-shafts or should they just be greased through the zirc fitting after assembly?
Thanks in advance,
-Fed
Old Aug 29, 2005 | 11:52 PM
C3nMe's Avatar
C3nMe
I used hi-temp synthetic grease (heavy duty) when I did mine. I would pre-pack them and apply a little after assembly. Mine still spit out a little grease after it was run for a bit ...but nothing worrisome.
Brian.
Old Aug 30, 2005 | 12:09 AM
Federot's Avatar
Federot
Great, that was my plan...thanks for the fast reply.
-Fed
To Greaseable U-Joints
