Anyone had this problem
Old Sep 2, 2005 | 09:36 PM
Techno's Avatar
Techno
I think you should first change the filter and eliminate the cheapest and easiest and most likely problem first.
Then go into the harder more difficult stuff.
If you have a plugging fuel filter what is happening is your fuel level is dropping too much. WOT is sucking it dry and light throttle isn't.
A rebuilt carb don't mean it was set up for your car. It just had new gaskets put in it. Secondaries that open too soon or too late don't limit rpms though. Its only a bog or loss of potential acceleration. It should still wind up.
Old Sep 2, 2005 | 10:54 PM
jeaux's Avatar
jeaux
changed to a adjustable vacuum advance and differnt springs and I bought the kit , was rattling at wide open throttle
Old Sep 2, 2005 | 11:45 PM
71LS5's Avatar
71LS5
St. Jude Contributor
Ok now I am wonder. I have posted here about my WOT detonation on a new rebuild. Are any of you detonating? If the carb is leaning out or droping fuel presure then would you for sure have to be detonating?
I have thought my fuel clunk sock could be cloged. I need to check my presure under load WOT and see it its the fuel. I will do this next week.
My Rochester 4MV carb was rebuilt as was the tack drive dist and was recurved. I AM RUNNING THE PERTRONIX AND NOW WONDER IF THIS COULD BE PROBLEMATIC TOO>.
The race guy down he street will not even look at the car unless he yanks the Rochester and the distributer to go with Edlbrock Performer and a better igniter. Like I said I want to keep it stock and the performer needs a square manifold which is out of the question.
What carbs are everyone running?
What distributer are you guys using? It needs tack drive.
Crap I rambled.....lol
Old Sep 3, 2005 | 12:45 AM
RatRacer's Avatar
RatRacer
I run a modified Quadrajet and a Mallory Unilite distributor with Hyfire ignition box on my 461ci LS5. It also has LS6 pistons, ported heads with big valves, ported stock intake and exhaust manifolds.
I also use a Holley Blue pump with a modified fuel pressure regulator that gives me 5psi at idle and 8psi at wot.
Car runs strong to 6k rpm.
Old Sep 5, 2005 | 07:05 PM
71LS5's Avatar
71LS5
Rat what Roch carb are you running? What the mods? What size metering rods etc?
Old Sep 5, 2005 | 07:34 PM
not a '76's Avatar
not a '76
humor me.
what did you gap your plugs to.
Old Sep 5, 2005 | 09:04 PM
71LS5's Avatar
71LS5
nota76 if your refering to me I gapped them a long time ago so I dont recall. Whats your theory? I will check tomorrow.
Old Sep 5, 2005 | 09:21 PM
71_LS5's Avatar
71_LS5
I believe I found my problem. Turned out to be an inoperable vacuum advance. Put the 8 dollar part on, retimed it to 36 degree's total and it screams.
Old Sep 5, 2005 | 09:32 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Glad you sorted it out. I just bought a second Vette, 71 454 and it also would just fly when I nail it than sputter. I realized the 10 bucks worth of gas I just put in was gone
Have fun with your ride...
Old Sep 5, 2005 | 10:07 PM
71LS5's Avatar
71LS5
ok just checked my plugs (one) I am running a foweled Autolite 23 with a 0.035 gap. I assume they are all foweled. Must be rich at idle and lean at WOT. Anyone have a good place for me to start hunting down if its spark or fuel related?
Old Sep 5, 2005 | 10:10 PM
RatRacer's Avatar
RatRacer
The carb is a big block truck replacement. The stock quadrajet was put on the shelf for safe keeping.
I have richer jetting than stock on all circuits. I also have a large inlet valve. Idle circuits were drilled per Doug Roes book. It's been a few years since I built it so it's a little vague now. I'll let you know when I find my note book. I've been looking for it for a couple days.
Old Sep 5, 2005 | 10:18 PM
71LS5's Avatar
71LS5
Thanks RAT. I was thinking of getting a Jet Roch but not sure which one. I would be interested in your mods.
anyone else have a recomendations to divide my problem up? IFuel delivery vs spark)????
Old Sep 5, 2005 | 10:21 PM
  #33
RatRacer's Avatar
RatRacer
I'd start by leaning the idle circuits slightly. Turn them all the way in and count the turns. Then turn them out turn the same position minus a 1/4 turn. Test the car to see if that had any effect.
It's also possible that the fuel wells in the bottom of the quad are leaking. It's always a good idea to epoxy over them when servicing the carb as they've been known to leak. The little rebuild kits usually come with a foam stuffer but epoxy is the way to go.
I never run anything but AC Delco R43TS plugs
Old Sep 5, 2005 | 10:32 PM
  #34
Techno's Avatar
Techno
Are the plugs fouled from the previous problem of no vac advance?
Old Sep 5, 2005 | 10:38 PM
  #35
RatRacer's Avatar
RatRacer
No advance would blacken the plugs.
Old Sep 5, 2005 | 10:45 PM
  #36
71LS5's Avatar
71LS5
Hummmm no vac adv would that cause detonation at WOT? I assume it would not. It would run more rich right? I am not sure how long its been fowled or what the cause is yet.
Old Sep 5, 2005 | 10:49 PM
  #37
71LS5's Avatar
71LS5
BTW just to be clear my advance might be ok its not been determined yet. I need some ones help put together a plan to debug this. Like what to look at first. Please keep in mind the carb was rebuilt with the engine and the distributer was recurved. I am using the Pertronix and thats why I jumped in here.....
To Anyone had this problem
Old Sep 5, 2005 | 10:56 PM
  #38
RatRacer's Avatar
RatRacer
No vacuum advance will make the car idle slower and force you to increase idle speed which causes run-on. You'll also get poor throttle response. The exception is if you run only limited mechanical advance. I run a Mallory with no vacuum advance but it only has 22 degrees of mechanical advance. I have inital advance at 15 degrees BTDC and final is at 37 degrees BTDC.
A stock distributor has around 30-32 degrees mechanical so if your vacumm advance isn't working you could end up setting you timing too far advanced and end up with more than 38 degrees total timing. That would cause a high RPM knock.
The best way to set up a distributor is with a distributor machine but they are hard to find nowadays. You can do it with a good timing light and a timing mark sticker for you torsion damper, but it's time consuming.
Old Sep 6, 2005 | 08:25 AM
  #39
71LS5's Avatar
71LS5
Rat my distributer was curved on a Sun distributer machine. All the weights and springs were new and reset for proper operation.
Old Sep 6, 2005 | 08:39 AM
  #40
not a '76's Avatar
not a '76
its not a theory. its pretty common knowledge in the turbo world. but since you had other problems spark blowout may not apply in your case. and i dont know what causes it exactly. so i cant provide any supporting theory besides a larger gap creates a more fragile spark.
spark blow out is what occurs at WOT when your gaps are too big. its happened to me on other cars. the solution is to gap down to 0.030 or 0.028. i had blow out at 0.035 but not at 0.030. and the car ran kinda rough all the time at 0.028.
plugs are dirt cheap. change em. gap at 0.03. and see what happens.
