Inspected your fuel filter lately?
Old Aug 30, 2005 | 07:09 PM
c3andc5's Avatar
c3andc5
Default Inspected your fuel filter lately?
My 73 had been sitting idle in the shop for several weeks undergoing some restoration. After picking it up I could tell right away it was responding rather sluggish. My first guess was right. Upon inspection of the fuel filter I found that the lower half of the filter where it sat in the fitting connected to the carb was caked with rust. This was a brand new filter only 2k miles ago. The moral of this story is for those of you whose C3s sit for extended periods of time, do yourselves a favor and check or replace your fuel filter before putting back in operation.
Old Aug 30, 2005 | 09:18 PM
rponfick's Avatar
rponfick
That's one reason I put an inline filter in the gas line back where the rubber line attaches to the gas tank. Out of the way and still looks stock.
Old Aug 30, 2005 | 10:04 PM
big_G's Avatar
big_G
1 guess where the rust in the filter came from....THE GAS TANK!...check it out, it probably has some at the bottom. Also check the pick-up sock. It may be split or clogged with rust.
Old Aug 31, 2005 | 02:49 AM
Twin_Turbo's Avatar
Twin_Turbo
I agree, if it's in the filter there's more in the lines and especially where it came from, the tank
Old Aug 31, 2005 | 04:51 AM
stingr69's Avatar
stingr69
I would pour in a bottle of gas dryer. One brand I see a lot is "HEET". Basicaly just some gas line anti-freeze that gets the moisture out.
-Mark
Old Aug 31, 2005 | 05:21 AM
c3andc5's Avatar
c3andc5
Well I have a new tank now, so maybe that could have been the source. I'm not familiar with the pick-up sock. Where is that?
Thanks, Chris
Old Aug 31, 2005 | 05:24 AM
Twin_Turbo's Avatar
Twin_Turbo
On the end of the fuel pickup tube in the tank there's a plastic woven pre filter that looks like a sock, they can become clogged with crud and not allow enough fuel through starving the engine
Old Aug 31, 2005 | 05:35 AM
c3andc5's Avatar
c3andc5
Ok I should have asked before. How do I inspect that...do I need a mirror to get inside the tank?
Old Aug 31, 2005 | 06:20 AM
Techno's Avatar
Techno
You can see inside the tank and vacuum it out through the gas fill, yours is still the large hand hole?
The bag is on the end of the pick up I think it should come out with the sender but yours is probably on top, not worth the trouble if it is.
To vacuum it use a hose and start a suction. It will take out any sediment or water.
Also those sintered filters on the carb are kind of lousy. Paper is a step up but better to use an inline filter. Much bigger and easier to change.
To Inspected your fuel filter lately?
