1973 - L82 engine optimization...
Old Sep 1, 2005 | 01:49 AM
73StreetRace's Avatar
73StreetRace
Default 1973 - L82 engine optimization...
Yesterday, I posted a thread concerning the advance parameters
of a delco remy distributor part #1112150.
The answer was quick ( thank you big_G ) and it was :
Centrifugal Advance:
0°@1200RPM
2°@1460RPM
12°@2200RPM
20°@5000RPM
Vacuum Advance:
0°@6"Hg
15°@12"Hg
So, my new question is to know if these advance parameters are
optimal or not for this engine :
Corvette 1973 - Small Block 350CI, L-82 ( 350 HP ),
Comp Ratio 9.0:1, Manual transmission ( 4 spd ).
Some minor engine modifications done :
Holley carb 4 barrel, double pumper, 650CFM,
Holley Street Dominator (2000-6000RPM ) intake manifold,
Edelbroke Waterpump,
Mallory Ignition MSD 6AL,
Mallory Performance Coil,
Holley Electrical Fuel pump.
New 4in1 stainless steel exhaust headers (equal length) ,pipes & mufflers.
All other engine parts ( crankshaft, rods, pistons, headers, camshaft...)
are stock and the distributor advance vacuum is linked to the Holley carb ported vacuum.
And of course, original emission control systems have been removed.
I must say that the engine performs well, but maybe it could
do better
Any advice or suggestion is welcome
Thanks !
Old Sep 1, 2005 | 04:54 AM
BigBlockk's Avatar
BigBlockk
Initial advance should be between 12 and 18 degrees BTDC. Centrifugal advance should be all in by 3000 rpm at WOT. Initial + centrifugal "about" 36 degrees. Vacuum advance should be hooked to manifold for proformance or ported for emissions.
If it rattles at WOT take some initial out of it.
You may also want to think about going a little richer at WOT if you're still useing the stock Rochester.
Well I guess I should have looked a little closer. I see you got a Holley on it.
BigBlockk
Later.....
Old Sep 1, 2005 | 06:45 AM
73StreetRace
Thank you for these informations BigBlockk
I will try these settings in a few days and I will keep
the forum informed of the results and feelings
Old Sep 2, 2005 | 10:10 PM
glen242's Avatar
glen242
Gonna need an aftermarket spring kit to get the 36* @2500 - 3000 rpm. Crane makes a nice kit.
If you have a damper marked out to past 36* you are ok, otherwise use timing tape, or better yet, a dial back timing light.
I set mine for 36 - 37*, all in by 2500, and I don't care where the initial timing is.
See Lars' paper.
Old Sep 2, 2005 | 10:32 PM
big_G's Avatar
big_G
BigBlockk
Later.....
Factory setting are usually conservative..
To 1973 - L82 engine optimization...
