Clutch feels weird
Old Sep 1, 2005 | 03:27 PM
76mike's Avatar
76mike
Default Clutch feels weird
How would I adjust the clutch? It's really tight.... it's pretty easy to push in, then gets tough, then is easy again near the floor. Ideas? Suggestions?
Old Sep 1, 2005 | 06:51 PM
Boofers's Avatar
Boofers
Does the clutch work okay as far as engaging/disengaging to the engine? Hopefully it does.
On the clutch linkage there is an adjustment nut that basically allows you to set at what point the clutch pedal pushed the clutch. If you look under the hood just above the oil filter (or around there somewhere) you will find it. You could play with this, just mark/remember where it was when you started so you can always get back to the start.
Old Sep 1, 2005 | 10:15 PM
76mike's Avatar
76mike
Yeah the clutch works fine, it's just that it's kinda finiky.
Old Sep 1, 2005 | 11:07 PM
lucky76's Avatar
lucky76
How old is the pressure plate and disc? If it's old and feeling weird then it's probably about had it.
Old Sep 1, 2005 | 11:58 PM
lostpatrolman's Avatar
lostpatrolman
Make sure the fork isnt hitting the footwells. I donno what happened, or went wrong, but someone put a clutch in my car and I had a problem of the fork hitting the footwells. It actually cracked the glass. The engine and trans soon came out, never did take it apart to see why it did that.
Old Sep 2, 2005 | 10:33 AM
rponfick's Avatar
rponfick
AIM recommends about 1 1/2" of freeplay at the pedal.
Old Sep 2, 2005 | 01:15 PM
not a '76's Avatar
not a '76
if its mechanical linkage and like my '69 then there is a grease fitting on the linkage. and a bad motor mount can really mess with the clutch if the engine has moved at all.
To Clutch feels weird
