door ajar switch
Old Sep 2, 2005 | 03:59 PM
jyoconnell's Avatar
jyoconnell
Default door ajar switch
on a 69, when you put the door ajar switch in do you install a washer on the outside of the fiberglass?
thanks
Old Sep 2, 2005 | 04:09 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
No washer here.
Old Sep 2, 2005 | 04:15 PM
jyoconnell's Avatar
jyoconnell
Thanks- does the nut on the switch recess into the hole in the fiberglass? I'm guessing it does not if there is no washer?
Old Sep 2, 2005 | 09:05 PM
GUSTO14's Avatar
GUSTO14
I believe it is really a pipe type thread that will tighten up before the switch actually bottoms out, at least mine did. If yours bottoms out that shouldn't be a problem as the new switch will seat at the correct depth the first time you close the door. It actually shoves it into the body of the switch as you close the door to the proper depth.
For this reason, used switches often don't work if you try to use them.
Good luck... GUSTO
To door ajar switch
