other than Bow-Tie Overdrives...
Old Sep 2, 2005 | 05:16 PM
Mike Mercury's Avatar
Mike Mercury
Default other than Bow-Tie Overdrives...
does any other company offer an all-in-one auto trans package like they do ?
Getting ready to drop the hammer on this purchase.
Old Sep 2, 2005 | 06:07 PM
page62's Avatar
page62
...are you starting to get the message yet?
Old Sep 2, 2005 | 10:49 PM
BigBlockk's Avatar
BigBlockk
How 'bout these people.
http://www.jetchip.com/transmissions.asp
BigBlockk
Later.....
Old Sep 3, 2005 | 12:08 PM
Mike Mercury
BigBlockk
Later.....
Thanks, I looked at their setup... apparently they are selling just a controller.
I remember reading here some time ago that Bow Tie wasn't the only company selling a complete 200R4 and 700 package with auto tranny, brace, hookups, etc... a;; that was needed.
Old Sep 3, 2005 | 12:47 PM
Twin_Turbo's Avatar
Twin_Turbo
Whoops wrong post
Old Sep 3, 2005 | 10:54 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i bought all my stuff absent the torque converter and trans from them and don't regret it at all. Its nice to have one stop shopping and i had no problems and they helped me over the phone for the install.
Old Sep 3, 2005 | 11:21 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
California Performance Transmission can sell you whatever you need. They don't have an online catalog yet, so you'll have to call them but they're very good. Just ask GSC3.
Old Sep 4, 2005 | 09:15 AM
mrvette's Avatar
mrvette
IF you have the time and a few tools you can just measure your stock setup, do some minor calculations and fab up your own stuff, it's NOT HARD....that's what I did when doing my 700r4 setup some 8 years ago...wish I knew of the 2004r back then, but time passes, and knowledge gained....
at any rate, mod the crossmember with some steel from H despot, and get it bolted in, then welded.....
I took out the muncie/bellhousing, and the new tranny, tipped them up on the housings flat on the floor, and took a framing square and steel tape to the things, comparing offsets vertically and length, the obvious was done without much effort....
GENE
Old Sep 4, 2005 | 11:35 AM
Mike Mercury
WOW ! Thanks for all the suggestions.
I can't seem to find a source for the 200R4 tranny locally. I've tried wrecking yards @ such.
BTO sells rebuilt & tested trannys, so I guess the fear factor isn't so bad then.
what TC did you use? Is it mandatory that a lockup TC be used in this swap?
Old Sep 4, 2005 | 10:02 PM
carl a's Avatar
carl a
mike,, why not have one built locally? my cousin owns a trans shop in chicago and built mine for me . using the right year for the core, bought all high preformance parts for the guts,,and boetie for the t.v cable,brake pedal switch,,indent plate for the shifter.and decal for the ''o.d'' and crossmember bracket,,boetie was on the phone with my cousin a few times,giving tips even thou we didnt buy there transmission then again this was almost 6 yrs ago,, i couldnt see paying boetie for a trans,if there was any problems i would be shipping back to california,,, any problems now i only got to get the 73 to chicago from the south suburbs,
Old Sep 4, 2005 | 10:30 PM
bobs77vet's Avatar
bobs77vet
i used a 2500 stall speed torque converter but i think a 2100 -2200 would also have worked fine....i don't know if lockup TC is mandatory but i think its a good idea.
Old Sep 4, 2005 | 10:45 PM
Mike Mercury
I looked into that. None of the local wrecking yards I called had any 200R4 - either rebuilt or just pull-outs. Then two transmission shops I contacted didn't want to mess with me. Acting like they didn't want any part of someone trying to put one type transmission in a different car that it never was available in.
I think it was due to concerns of me bringing it back - for something that (to them) wasn't their doing.
It was so frustrating that I gave up on that avenue.
Old Sep 5, 2005 | 12:19 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
http://www.cpttransmission.com
I believe that their webpage is down, but I'm sure that they are available by phone...
That's where I got my transmission kit from .. It contained everything needed (except the yoke)...
It's holding up behind my 600 HP engine and slicks.. 48 passes on the tranny so far!!
To other than Bow-Tie Overdrives...
