My rear sway bar
Old Sep 5, 2005 | 07:55 AM
norvalwilhelm's Avatar
norvalwilhelm
Default My rear sway bar
After reading a good article by Herb Adams and talking to Twin Turbo I decided to install a rear sway bar. Being nose heavy my car would tend to understreer anyway. Fitting a bar is not easy with the big tires and 6 ½ inch offset rims. I also further complicate it with fuel filters and twin pumps mounted in this area.
I decided to go with a speedway bar and arms , like the front and install the bar by welding mounting plates to the rear crossover frame directly behind the removable cross member. The widest speedway bar made is 43 inches. I went with 1 ¼ OD and .187 wall.
I won’t go into details because it only pertains to my car and it’s problems with mounting.
Here are a few pictures of the installation.
Old Sep 5, 2005 | 08:33 AM
fl_rider's Avatar
fl_rider
Default Nice!!!
Norval you have done it again.
Keep up the great work.
Chris B
Old Sep 5, 2005 | 08:59 AM
BerniesVette's Avatar
BerniesVette
Norval,
Have you had an opportunity to see if it helped with the understeer yet?
Bernie
Old Sep 5, 2005 | 11:02 AM
norvalwilhelm
Originally Posted by BerniesVette
Norval,
Bernie
Thanks Chris. I was desperate to find something to work on
Bernie I have not driven the car yet. I intend to do that now but only a very short drive to settle the suspension and then adjust the rod ends so there is no preload on the bar.
I have considered weighing the car on all 4 wheels then try adjusting the bar to shift weight from side to side but not sure if that is acceptable.
I will go to a vacant paved lot and try pushing it around a few hard turns to see if it oversteers or not.
Old Sep 5, 2005 | 02:27 PM
Techno's Avatar
Techno
Its nice but not shiny enough
Old Sep 5, 2005 | 02:40 PM
Twin_Turbo's Avatar
Twin_Turbo
shiny schminy, it's about performance, looks comes second, the holes in the sway bar arms look good, and they weigh nothing
Old Sep 5, 2005 | 02:50 PM
norvalwilhelm
I just took the car for a run. It is definitly stiffer. I will have to get use to the increases ride harshness. I did throw it around a corner at 60 mph and it felt like the rearend might come around. Being on a public road with ditches bothered me and since I had no drivers licence with me I felt I shouldn't use the paved vacant lot at the local high school. That is where I want to really try it. No ditches and lots of open space and it is located in the country, far from surrounding homes.
The arms start out 3 times that long, solid and weigh alot. By the time I am done they are about 2 1/2 pounds.
Old Sep 5, 2005 | 03:16 PM
Empatho's Avatar
Empatho
looks good hope you get to try it soon at the parking lot
Old Sep 5, 2005 | 03:22 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i added one to mine and it helped a lot!
To My rear sway bar
