WHAT IS A "BIRDCAGE" ?
Old Sep 7, 2005 | 06:12 PM
Herb396's Avatar
Herb396
Default WHAT IS A "BIRDCAGE" ?
putting myself out there,,I've read comments about checking for birdcage rust,,,but I have to admit,,,I don't know what or hwere it is,,
help please
Old Sep 7, 2005 | 06:28 PM
RatRacer's Avatar
RatRacer
The birdcage is the frame that goes around the cockpit and windshield. It is covered by bodywork everywhere but the A pillar next to the windshield. Most C2's and C3's have some rust in the area under the A pillar, some worse than others. It's next to impossible to repair substantial birdcage rust without doing a major body off restoration. Fortunately, unless the bircage is wasted, it's not very critical because chassis relys mostly on the main frame for structural rigidity and integrity.
Old Sep 7, 2005 | 07:53 PM
SuprJames's Avatar
SuprJames
Not critical until you start getting water leaking around your windshield or your doors start sagging. Once it starts to rust it had better be stopped quick. I just finished repairing mine. Luckily it was only the area around the windshield.
Old Sep 7, 2005 | 08:16 PM
RatRacer's Avatar
RatRacer
Yea, I've seen some pics of wasted ones from Northern cars where the area below the A pillar is completely rusted through. You don''t see anything like that where I'm from.
So did you just pull the windshield/trim and weld the A pillar up?
Old Sep 7, 2005 | 08:42 PM
SuprJames's Avatar
SuprJames
I had a friend from a local bodyshop come over and we did the work together. First I cut the rusted areas back to where there was good metal. Then, my friend made patterns and then cut the metal patches. We then welded them in and used duraglass (I think that's what it's called) to fill in to make it smooth. Then, because he's a perfectionest, we ran body filler over it and sanded it down. It turned out better then I ever thought it could. After all that I squirted rust blocker inside the windshield frame with this cool wand at the end of a long flexible tube that sprays the stuff in like 6 directions and forward.
Old Sep 8, 2005 | 03:09 PM
tiger9297's Avatar
tiger9297
I'm glad someone asked that question because I had wondered the same thing myself. Nice to have a source where guys like me can learn from those with much more knowledge and experience.
To WHAT IS A "BIRDCAGE" ?
