Order of improvements
Old Sep 7, 2005 | 06:27 PM
Leo001's Avatar
Leo001
Default Order of improvements
I would like to do some improvements over the winter, but don't want to do things in the wrong sequence. If I were interested in purchasing and installing a "suspension kit" (shocks, sway bars new rear spring bushings etc...) as well as rebuilding the rearend (leak) should this all be done at the same time, and should I rebuild the Tarms also?? I know it's a lot but it seems to me it would be cost effective (labor wise) do do it all at one time.
Any sugestions??
Leo
Old Sep 7, 2005 | 07:11 PM
chris75stingray's Avatar
chris75stingray
it should all be done at once if you have the $$ because i'm guessing it would be alot easier to get to the rear end with the suspension out.
Old Sep 7, 2005 | 07:23 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Leo,
Common problem and many of us have done the same project. Don't chew off too much at the same time. Best thing is to work on all the rear or all the front at one time. There are always "while I was there" projects that will stretch out your one weekend of rebuilding.
Figure one weekend to tear down the rear suspension. Get some demolition blades and a sawsall to cut the trailing arm bolts. Start soaking every bolt/nut/joint with PBlaster now. Spray anything you intend to pull apart once a week for the next month. It will save you a lot of apin when you get to winter and go to pull everything apart.
You will need at least a week (after work 2 hours a day) of cleaning/corrosion control/painting and another weekend to put everything back on.
You can rebuild a lot of stuff yourself to save money but companies like Van Steel do suspension every day and usually give free shipping also.
Once the rear is done then progress to the front.
Buy some POR15 for the frame. Stuff is tuff and works great.
Good Luck.
Heres a pic to inspire you.
Cheers,
Pete
Old Sep 7, 2005 | 09:34 PM
rosslato's Avatar
rosslato
Originally Posted by stingry
Leo,
Good Luck.
Cheers,
Pete
well said. your rearview is gonna look outstanding, make sure to post pics when you're done
To Order of improvements
