Where Does This A/C Wire Go?
Old Sep 8, 2005 | 06:15 PM
KALAWAY's Avatar
KALAWAY
Default Where Does This A/C Wire Go?
Hope the pic works. The brown wire on my '75 A/C compressor is disconnected. The green wire is attached.Don't know where it goes. It is exposed on the end with insulation cut off. No plug or anything.
http://img.villagephotos.com/p/2005-...Compressor.JPG
Old Sep 8, 2005 | 07:00 PM
WhichVette?'s Avatar
WhichVette?
Does it go to the second pin of the AC connector? If so, I think it goes to ground to complete the circuit when you turn on the AC (activates the clutch).
Old Sep 8, 2005 | 11:28 PM
jeaux's Avatar
jeaux
Ok on my 75 two wires go to the plug which you have ,then a black wire provides a ground to the ac comp. bracket the tan wire goes to one side of the pressure switch right there below the a/c sight glass in your picture the tan wire comes out of the bundle going to your blower motor my dig.cameras shot hope this helps
To Where Does This A/C Wire Go?
