Gear select Legend Plate
Old Sep 8, 2005 | 10:54 PM
David Ey's Avatar
David Ey
Default Gear select Legend Plate
Looking where to buy a different plate for the shift selector so the new 200r4 will show all four foreward selections. Isn't this all it takes inside the car to make the shift work right? If not, where do I get what I need?
Old Sep 8, 2005 | 11:08 PM
wombvette's Avatar
wombvette
I dont quite understand what you are looking for. The detent selector plate or just the indicator plate. If you are just looking the indicator plate. Go to a trophy shop and show them what you want.
Old Sep 8, 2005 | 11:15 PM
JonnHeather's Avatar
JonnHeather
Call BTO, they have them...
Old Sep 8, 2005 | 11:17 PM
David Ey's Avatar
David Ey
I dont know what I mean either. Just want the shifter to work right and the selector plate to show 4 forward gears. Is there a detent plate worry about too? I need a lot of help I guess.
big_G's Avatar
big_G
You should be able to use the shifter and console trim plate from an 82 vette, (the only C-3 that had a 4 speed auto. trans.) Ecklers and others sell the shifter conversion kit to use your 3-speed shifter.
http://www.ecklers.com/product.asp?p...USQ8LS2HDKAQK1
Old Sep 9, 2005 | 08:34 PM
David Ey's Avatar
David Ey
Thanks BigG.....I'll order one NOW
To Gear select Legend Plate
