Bilstein or Koni
Old Sep 8, 2005 | 10:57 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Default Bilstein or Koni
I've had Bilsteins on numeous other (german) cars but Koni's were historically popular on these cars.
I'd like to hear some opinions.
Setup:
1972 BB stock front springs, fiberglass rear. KYB right now but a bit too soft for me
Thanks!
Old Sep 8, 2005 | 11:18 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I, just recently, installed a set of Koni at all 4 corners. They ride a little softer and smoother than the Bilstiens I had on. So far, I have been well pleased.
Old Sep 8, 2005 | 11:53 PM
Solid LT1's Avatar
Solid LT1
Bilsteins are lower priced but, come in 2 versions HD and "Sport". Konis ride well if you leave them at the default settings and don't screw them in as the adjustments are rather drastic and meant to allow for long term useage (need adjustment every 80-100K miles.) Many people who complain about Koni harshness have turned their dampnening rates sky high through ignorance of the Koni adjustment system. Haven't heard much feedback on Edelbrock shocks but, I like my RCSI shocks from Mid America and the can be tuned to ride really well and dampnening turned up for the track. I HATE! KYB shocks and won't run them on any Vette I work on, my humble opnion.
Old Sep 9, 2005 | 12:26 AM
flynhi's Avatar
flynhi
What shocks do you guys recommend for front and rear composite/fiberglass springs?
Old Sep 9, 2005 | 01:38 AM
Graemeinvette's Avatar
Graemeinvette
Bilsteins or Koni, definitely. As previously said they have slightly different characteristics but they are both very tuneable.
Old Sep 9, 2005 | 03:23 AM
art-corvette's Avatar
art-corvette
dunno about the bilstein.. but i was thinking about the koni and was told the vendor (VBP) of my monospring gives the advice to use the ACDelco shocks.
art-corvette
Old Sep 9, 2005 | 04:23 AM
Graemeinvette
Much as I like VBP and I have used them a lot, I would go with the Koni's. I'm using Spax gas adjustables and these work very well, but I'm not sure if you can get them in the USA.
Old Sep 9, 2005 | 08:56 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
art-corvette
Did know they even sold Delco's. Just KYB's and Bilsteins. Are you sure it was Muskegon?
Old Sep 9, 2005 | 09:01 AM
flynhi's Avatar
flynhi
At the suggestion of VB, I'm currently using KYB-GR2s which are fine for my composite springs at speed on smooth roads but way too stiff on irregular city streets.
Are you recommending the red Konis that adjust by rotating the steel center shaft or the Koni with the adjusting **** on the side?
Are you recommending the Bilstein HD or Sport?
Thanks.
Old Sep 9, 2005 | 09:24 AM
Lee H's Avatar
Lee H
I have Bilsteins on my 65 & 75 corvettes. Also on my wife's Jimmy, my Z71, and my dauther's extreme. I think they are about the best shock made. Seem to last forever.
Old Sep 9, 2005 | 01:10 PM
redvetracr's Avatar
redvetracr
If you OR anyone else is interested I have (for sale) a set of (almost) brand new single adjustable Koni`s they appear new but have about 50 miles on them, I got them from C/F member Twin Turbo, these are made in Holland by Koni opposed to the ones you can buy here made by ITT. I paid him $300 and want $300....interested parties SHOULD e-mail me direct!! redvetracr@msn.com
Old Sep 9, 2005 | 01:37 PM
65 Hardnoks's Avatar
65 Hardnoks
I'm satisfied with my KYB's.
Old Sep 9, 2005 | 01:56 PM
flynhi's Avatar
flynhi
redvetracr,
I'm curious as to why you changed to what you are using now.
Old Sep 9, 2005 | 03:17 PM
CruisinCO's Avatar
CruisinCO
If you don't mind spending the extra few bucks...... QA1's with my fiberglass spring on my 69 and the ride is unbelievable now!
They are totally adjustable depending on what your driving habits are.
Old Sep 9, 2005 | 03:43 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The KYB shocks are inexpensive and "sufficient" for a "normal" driven car...
I recently sold my KYBs because they were too soft for my taste, I installed the 550lbs VBP springs and four Bilstein HDs - a huge improvement (now I need a stiffer rear spring )
Unless you want to race the car and fine-tune the suspension I don't think it's necessary to spend the extra $$ for the Konis.
Old Sep 9, 2005 | 08:39 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I originally had KYB's on my '72. I took them off after 1,000 miles because I found them to be too soft. I installed the Koni's and have been very happy with them. I like the fact that they are adjustable allowing you to fine tune them to your suspension. However they have to be removed to adjust them (easier). There are other brand shocks now avilable that can be adjusted on car.
Old Sep 11, 2005 | 11:03 AM
flynhi's Avatar
flynhi
Anyone know where I can get the compression and rebound measurements for Bilstein and Koni shocks?
To Bilstein or Koni
