C5 LS1 into '72 Info Inside
OK, first thing I can tell you is that the accessories are all over the A-Arms. As with the Camaro LS1, the heater hose outlets need to be removed and relocated and the inlet on the waterpump will later have to be changed. The AC Compressor, steering pump pulley, and the bracket that holds the steering pump and altenator (one big bracket) all hit the A-arms. I might be able to use the altenator/steering pump bracket without the steering pump, but it would require some modification and I don't know if it would work with the Street and Perofrmance brackets that I'll probably end up buying. So I'm probably just going to buy all the accessories and brackets from S&P (ouch!!).
The "batwing" oil pan is really close to the power steering cylinder. I haven't got the T56 tranny in yet, so the engine may be tilted farther down or up which might cause it to hit. I'm fairly certain it won't though, and the batwing offers better ground clearance then the Camaro oil pan. It will be intesting to see how the Steeroids works with that oil pan.
I also did some preliminary measurments with the stock small block hood on the clearance I'll have. I'm planning on going to a Magnuson supercharger later and also a big block hood. I'm hoping that no modification will be required on the new hood. Keep in mind these might change a bit since the tranny isn't in place yet. Despite how the picture looks I have 2 1/8" of clearance and on the back of the plennum I have 2 3/4" of clearance. No comments from the peanut gallery on anything my putty might resemble.
If anyone wants me to measure anything or take pics of anything I'll be happy to. I'll also be putting LS6 heads and modified (to fit the heads) stainless steal Hooker Sidepipes on this car, so should be interesting.
Nice work so far. If my car wasn't so original I would get a GM crate motor LS1 and stick one in myself. Keep us posted. Pics are always appreciated. Especially how you solve the A-arm clearance issues.
Pete
Questions.
Are you going to ditch the fly by wire?
What fuel system are you going with?
Questions.
I might pick up a set of F-body brackets, but I still wouldn't be able to use the AC right? My understanding is that the S & P AC bracket won't work with the F-Bod brackets and I really need AC. Living in Florida and having a car that will be black absolutely requires it. If you're running AC I'm all ears for alternatives.
I'd like to keep the electric throttle for the
factor. I know they make kits, but I haven't looked at how much they are or done any research on them yet.When I did the fuel injection on my '82 I used an aftermarket in-line pump that worked pretty good. Might go that same route if possible. As for the injectors whatever comes with the Magnuson (42#??). I'm also considering using Accel's Calmap for engine management instead of the stock computer. I have a tuner down here that did some work on my '82 swears to me he can put a better tune on it then anyone. I haven't given the fuel system much thought. Right now my mind is on getting everything set to pull the body.
There are plenty of people running maggies on Z06's in this forum. I also talked to magnuson and the guys at Lingenfelter before buying these heads. I thought the same thing about the compression, but perhaps because it only runs a max of 8 lb. and only like 5 lb. on the LS1 to avoid detonation. Gets more HP then the truck motors though.
Nothing is final yet and I'm probably at least a year away from getting the engine cranked. I have quite a bit more research to do before I make any final decisions.
QUOTE]
S & P has a kit to just add A/C to the top pass side. It made for a sanderson compressor and you just add a longer belt. You could also just make some plate brackets for a 84 vette compressor.
I would pull the sending unit and graft in a pump. I'm not sold on the frame mount with a late model tank. Just pull it, cut the pipe with a tube cutter, and braze in a bracket to support the pump. Some FI rubber tubing and your there. I using a late model LT1 pump that was used and it been running for 5 years and two motors.
Cool ride, by the way.
keep us up to date
