76 still won't start, need help please
Old Sep 11, 2005 | 03:51 PM
GuinessGary's Avatar
GuinessGary
Plugs are ok, they were replaced last year. Checked for spark and it is not blue/white, it is orange. The choke and float are open and they work properly. What's left to check in the electrical system?
Old Sep 11, 2005 | 03:55 PM
Twin_Turbo's Avatar
Twin_Turbo
Check the engine ground strap, it's on the pass side going to the underside of the engine mount
Old Sep 11, 2005 | 03:57 PM
GuinessGary
Looking at a picture of all the components in the distrubutor. There is a piick up coil, could that be a problem?
Old Sep 11, 2005 | 04:04 PM
GuinessGary
If there was a problem with the engine ground strip the engine would not run at all? The vette has power but it will not fire up the engine.
Old Sep 11, 2005 | 04:17 PM
steves_77vette's Avatar
steves_77vette
On HEI distributors you have a BAT terminal with a red wire going into the clip that connects to the dist. Get a meter and poke the positive lead up into the underside of this clip with the entire thing assembled. Connect the negative lead of the meter to something on the block, anywhere with exposed metal will do. Now, in the ignition off state you should have nothing, 0V. Turn the key but do not start it and you should have +12V or slightly higher. If you don't then you have an electrical problem of some kind leading to the dist.
Now, with your helper, start the car and watch the voltage on the meter during the opertion. If it is dropping below 12V then you have a weak BAT or ground problem on your car. If it stays solid then your problem is somewhere else and move on. The real key in your case sounds like comparing how the power into the dist is behaving before and after you have the problem.
I had an electrical problem about 3 weeks ago that resulted in an unstabled +12V going in to the BAT ternminal and it made my car run like poop. Never could get a solid idle, etc.
Old Oct 6, 2005 | 08:11 PM
anmracing's Avatar
anmracing
St. Jude Donor '09
I wonder if Gary ever got this figured out....
I wonder what it turned out to be...
Andrew
Old Oct 7, 2005 | 08:55 PM
GuinessGary
The vette still won't start after the latest test. I don't want to repeat myself and sounds boring. I have too many posts on this problem. I always have questions but the bottom line is still the same. Please read my post regarding the engine ground strap. Looking help always, thanks, GG
Old Oct 7, 2005 | 09:07 PM
Zzap!!'s Avatar
Zzap!!
You need more than just fuel and spark to make an engine run. You also need "AIR" and "EXHAUST". If you can't breath, you choke. If you can't fart, you'll cramp up and die.
If the car is parked outside a lot, look up the tail pipe and see if anyone's shoved anything up it's *** (like a spud). If the pipe seems free of any signs of mischief, look at the breather. Chances are, though, it's probably the choke stuck on full position.
Old Oct 7, 2005 | 09:18 PM
David Ey's Avatar
David Ey
Zzap, thats a good thing to check. Could be stopped up.
Gary, check both ends of your plug wires to make certin they are fully plugged in....dist and plugs.
Old Oct 8, 2005 | 12:28 PM
GUSTO14's Avatar
GUSTO14
Gary,
You mentioned an orange ignition spark, but I can't recall if you said you had changed out the ignition module/coil or not. These do go bad and can cause your problem. You seem to have eliminated almost everything else.
Good luck... GUSTO
