How do I install my new lower control arm bushing? I guess the real question is how do I remove the old ones. I have the control arm out but have no idea what do do next. Thanks for any help.
I just did this last weekend... use an air chisel or a regular sledge and chisel on the outer lip of the bushing to get it out of the control arm. you'll have to work it out a little bit at a time, but it'll come... as always lots of PB Blaster and a torch does wonders. So does an 8 or 10 lb sledge with the handle shortened.
Another method to try is to get a chisel (air or conventional) on the edge of the sleeve that is on the end of the cross shaft, and try to work it out from there. Another thing that helped me a little bit was to drive the cross shaft through the control arm from the opposite side, and this will help get the bushing out - but be careful of the inner threads on the cross shaft.
I guess the main thing is that the job is just a pain... take your time, and you'll get it out.
If you're like me and don't want to spend an afternoon beating the snot out of your contol arms, take 'em to your local mechanic and have them replaced using an air press. Only cost me $40 for all four control arms here in MN.
it took me like 40 minutes to do them all.i have an airchisel and acces to a press but i like the bfh.
I think it's probably worth mentioning at this point what some of us may have already found out the hard way, these control arms can quite easily be distorted when removing and installing the bushings, so ...let's be careful out there...
Personally I have to agree with 7T9Shark it's a whole lot easier to take them to a machine shop and have them replaced for a small fee than to start over with a un-bent control arm...
This method for use with poly bushings only ... not OE rubber.
IF ... ONLY IF ... polyurethane CA bushings are going back in ... the OE outer shells do not need to be removed/chiseled/bfh'd ... as they can be reused in place right where they are. Simply cut out the old rubbers & old inner shells with a hole saw / pen knife ... clean old outer shells 'til spotless inside. The simply slide in the new inner shells & poly bushings w/silicone grease ... clean out the shafts' retainer bolt holes w/ carb cleaner ... install the retainer bolts w/loctite.
On the other hand, if going back with OE type rubber bushings ... use great care ... as mentioned the CA's can easily distort.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I've seen members here posting that they took a torch to the rubber.
I used a 1/8" drill bit and drilled holes in the middle of the rubber all around the perimeter. I then dug the rubber out with a screwdrivwer and scratch awl. Keep drilling holes until rubber pieces start falling out, that's when you know you're on the right track.
I tried using a propane torch. Although it was working , it was taking a long time. The rubber did not burn as I thought it would. Perhaps a welding torch, which is hotter, would lessen the time. I drilled holes through the rubber. If the rubber is still good, the drill bit will not want to go where you want it to. It had a tendacy to wander to a previous hole. As jughead mentioned, once pieces of rubber start coming out you basically got it licked. Getting the bushing out was sort of a pain but I found getting the outer sleeve out to be more difficult. After replacing all 8 bushings I still don't have an easy way, although the upper bushings are easier.
