header wrap
Old Sep 10, 2005 | 07:40 PM
painterman52's Avatar
painterman52
Default header wrap
When installing header wrap is it better to remove them or just wrap them on? There is a kit from summit that includes a spray can of something, is it necesary or just for looks?
Old Sep 10, 2005 | 07:43 PM
fl_rider's Avatar
fl_rider
It keeps the heat inside the pipes and out the exhaust.
This is supposed to help the engine run better and it also helps cut down on the temps in the engine and passenger compartments.
Old Sep 10, 2005 | 08:50 PM
norvalwilhelm's Avatar
norvalwilhelm
Far better to do it off the car. I think it would be impossible to do on the car anyway. Also a tip. Soak the wrap for at least 15 minutes in water before wrapping. The wrap will be so much more pliable. I really like the stuff
Old Sep 10, 2005 | 09:06 PM
Empatho's Avatar
Empatho
it works great its helps allot with underhood temperatures, its better to do it with the headers out of the car
Old Sep 10, 2005 | 09:10 PM
David Ey's Avatar
David Ey
what if you wraped coated headers? would that help too?
how about just past the header and back under the car? would that help on the heat problem?
Old Sep 10, 2005 | 10:54 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I couldn't even imagine how horrible that would end up looking. I used the exact kit you are looking at earlier this summer. Made by DEI. I used the spray. Now my header wrap is black. I think that's the only reason for it. I took Norval's advice and soaked the wrap before installing it. You should do the same.
Old Sep 10, 2005 | 11:20 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i have also wrapped the front y-pipe (c4) and the cat
To header wrap
