82 won't start
I would check the fuel pump relay first (since you already checked the fuses), it's on the passenger side backwall under the storage box liner.
While you're in there, also check the big metal box in the plastic holder with the fiberglass reinforced tape holding it together, that's your wiper control module, usually the tape dries out, the module falls out it's plastic holder and shorts on the jack, this has nothing to do with your problem but it's a nice while I'm at it job, those control modules are hard to find
Do you hear the fuel pump running for a few seconds with the ignition on all i here is a 2-3 second clicking sound. I think it is the relay.
does it also on when cranking (hard to hear) havent really paid attention. i would think i need a second person to stand in the rear
I would check the fuel pump relay first (since you already checked the fuses), it's on the passenger side backwall under the storage box liner. since the relay is clicking, can i assume its working or should i use a multimeter to test it?
While you're in there, also check the big metal box in the plastic holder with the fiberglass reinforced tape holding it together, that's your wiper control module, I recently replaced the wiper module. I found it at a local Corvette repair shop.
If there's no 12 v when the relay switches (and it only activates a couple of secs after turning the ign. on ...when testing turn ign off for 30 secs before trying again or the ECM won't activate the relay again) check at the relay. Is there 12V (after turning ign. on) on the tan/white wire? If yes, the problem is up ahead possibly in the fuse box (fuse is in this tan/white wire circuit on the fuse box) if not, the relay may not get a 12V ignition switched feed, this is a red wire and there's 12V on it whenever the ignition is in the on position.
If you need a wiring diagram go here
http://www.crossfire.homeip.net/faq/diagnostics.html
My money is on the pump being shot since this came on after a longer stand still. Now if it turns out to be a defective pump, you need to remove the fuel door assembly and then remove the 8(?) bolts that hold the fuel filler/metering unit to the top of the tank, removing the metring unit from the tank and then getting it through the hole in the rear deck takes some twisting and trning, it's a bit of a puzzle but it should come out without paint damage.
If you replace the pump, get a DELCO unit, preferrably the 85+ pump since the stocker barely puts out the needed flow and psi in new condition.
Here's an article on replacing the pump
http://www.crossfire.homeip.net/cfte...ID=18&CAT_ID=1
One thing you also need to do when replacing the pump is clean out the gas tank, often a bunch of water collects in the gas tank and sits at the bottom, this kills fuelpumps when they are submerged since water doesn't lubricate and it can lock the pump up due to corrosion
I don't know what schematics you have but here is the entire enchelada and no yellow wire in this one
What harness connector are they talking about. Neither the FP relay nor the oil pressure switch have a blue cable.
PS. I connected a test light directly to the FP fuse and am not getting any power to the fuse at all.
There's a blue wire just before the level sender harness, so at the tank..not at the relay (running from the fuse to the pump, before that it's tan/white and after the connector it's blue, then at the tank connector it's tan/white again.
The FP fuse is located AFTER the relay and pressure switch so if there's not 12v there it can be either, is ther e12V when you turn the ign on or is there never 12V? There's only 12V w/ ignition on if the relay is working, there's only 12V from the pressure switch if the engine is running w/ proper oil pressure. Look at the diagrams it's all in there.
#2 Is the relay energising? YES
If the relay is energising, and you have power at terminal "E", but nothing at the fuse, you either have a bad relay or a bad connection between the relay terminal "A" and the fuse. I agree, but shouldn't the fp run if I jump the orange wire terminal E with the tan/white wire terminal A? When I try this, the pump does not run. By process of elimination, I guess there is a bad connection between the relay terminal A and the fuse. Can I assume this?
