Brake problem
Old Sep 12, 2005 | 06:19 PM
jeaux's Avatar
jeaux
Default Brake problem
I lost a lot of brake fluid on the back side so I took the wheels off and saw some fluid standing on the inside of the rim but no real indication of the source so I had my helper pump the brakes still nothing only a small spot on the bottom corner of the caliper where it look like it may of been damp is this a leaky o-ring?
Old Sep 12, 2005 | 08:22 PM
62fuelie's Avatar
62fuelie
You likely have a leaky piston seal(s). I would replace or rebuild the caliper immediately.
Old Sep 12, 2005 | 08:43 PM
Perfomer's Avatar
Perfomer
I have4 the same problem if i don't drive my for several weeks. I use DOT 5 brake fluid . You will be better off buying a caliper than trying to rebuild the old one . You can get them at Advance or Auto Zone with a life time warranty .
Old Sep 12, 2005 | 08:53 PM
jeaux's Avatar
jeaux
Thats just what happened I let it set about 3 weeks fluid low and a spot on the floor but my wheels off now and no fluid dripping.
Old Sep 13, 2005 | 12:23 AM
62fuelie's Avatar
62fuelie
Just because it's not leaking in a static condition doesn't mean that it won't start again as soon as you start driving it. Calipers are about $60 exchange at your favorite parts store. Don't screw around with brakes.
Old Sep 13, 2005 | 08:18 PM
Tom454's Avatar
Tom454
Most likely the piston seals, which you cannot see from the outside. The seals you see are the dust seals or dust bots. I have done brake jobs where the piston seals are fine, but the tiny o-ring that seals the fluid passage between the two caliper halves was leaking. The piston seals will last the longest if the car is driven regularly. Otherwise, even if they are new, they will "flat spot" and start to leak, regardless of what type of fluid is used. Once the seals flat-spot, they have to be replaced.
Old Sep 13, 2005 | 08:46 PM
jeaux's Avatar
jeaux
I'm not doubting it is the brake I just want to understand why it's not leaking when we pump the brakes. why did it leak a puddle on the floor but it's not leaking now?
Old Sep 13, 2005 | 11:20 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
If they are not SS sleeved they will. If they are lip seal, they are prone to leak if they sit. O-Ring is the way to go.
Old Sep 14, 2005 | 09:27 AM
Tom454's Avatar
Tom454
===> I'm not doubting it is the brake I just want to understand why it's not leaking when we pump the brakes. why did it leak a puddle on the floor but it's not leaking now?
Unless you have a catastrophic failure, brake leaks are slow.... not like a running faucet. Whether you are pumping/using the brakes or the car is just sitting, the fluid just seeps out slowly. A brake system should be 100% dry at all times. If there is any sign of fluid, you have a leak, regardless of whether the system is pressurized or not.
I used to do NYS safety inspections in the late 70's and one of our standard checks was to pull all wheel cylinder dust boots back to peek under them... if there was any signs of fluid whatsoever, it was legal grounds for an inspection failure. Needless to say, I did a lot of brake jobs.
Old Sep 15, 2005 | 05:07 PM
jeaux's Avatar
jeaux
I took a chance on Auto Zone since I only need one at this time and I have a new one on the car from the previous owner
the only problem is the warranty will be void if I paint it to match the others
Old Sep 18, 2005 | 12:06 AM
62fuelie's Avatar
62fuelie
You're worried about painting a caliper? I'd be worried about stopping the car.
To Brake problem
