Which TV Cable to use?
or the one from the tranny: 1991
I'm having TH700R4 reinstall TV Cable Adjustment issues. No upshift whatsoever, at low speed at least. I'm too chicken to floor it yet.
I now have gauge/hose/fittings, but before I do go that far...
I was hoping someone could let me know if the 1982 cable on the car could be screwing up the TV adjustment? Should I swap em try again? Known issue I'm missing out on here?
Last edited by 82XFire; Sep 13, 2005 at 12:56 AM. Reason: speeling error deeeeeeeerrrrrr
Off comes the pan tonight and I think the 91 TV Cable is going on as well.
Quincy huh? My little brother spent 4 years down there at Quincy College in the mid 90s. Great little town when the river isn't getting cranky. We're originally from the Peoria area. I was back last week for his wedding, I miss the changing seasons once in a while.
I have no up-shift at partial throttle (I won't test the WOT shift until I have some kind of shifting). Does that indicate that the cable needs to be adjusted in? Thereby concealing more of the inner cable?
IS IT THE RIGHT CABLE? Are there different lengths for different years? Should I use the cable from the tranny or the car?
Anyone?
Aha! I have now confirmed there are different lengths, thanks to
Timbo. Now to figure out which cable to use......
Big G, I have over-researched this and the breakdown from GM, Bowtie, and Transmission.net is that ALL shifting functions are handled by the TV plunger. The plunger controls the pressure-up for the shift, if it's not in the right spot= no pressure up and no shift (then burn-out), or over-pressure due to confused transmission (no shift/early shift/improper shifting)>then burn-out.
Out of adjustment on either side may produce nearly the same symptoms which makes this so much fun!
The transmission is a 1991 TH700R4/4L60 with about 30,000 miles on it. Looks cherry with no dents in the pan or anything... It's from a C4 Vette that got parted out to a local dealer.
I should have went with the 6 speed....
I'll save that for the Newman chassis and the 63 1/2.
Already got most of that data. Bowtie is really thorough in their documentation. I believe I have a pretty good comprehension of the mechanics involved.
My car, 1982 CE, was the first year with the 700R4 and I was hoping that the stock cable would work, now I'm starting to wonder since its only coming out 2 clicks on the adjustment and I'm not getting any shift action whatsoever. How critical is the cable routing? Any special clamps, brackets, or curves that need to come into play.
I will pull it out if it doesn't start working soon. I am far more familiar with clutches and pedals than ATF.
There's only so many hours I can screw with it and none of the local shops have proven knowledgable, worthy or honorable. Several have tried to hose me so bad that hostile words were exchanged.
BUBBA SUCKS A BIG ONE!
I am just as stumped....
Do you have a "lock-up" on it?? basically 12v going to the brake pedal. I know a friend has his "lock-up" wired wrong and had nothing but problems until he discovered it. Just a thought.
The cable was not unhooked from the intake during the swap and was left on the car. No snags or binding. Smooth return with car on/off, park and idle. I checked the length of it for any snags, burrs, burns, etc. Looks really good...
I compared cable from car to cable that came with tranny. The cable from the newer tranny is shorter. Must have been a C4 thing.
I checked the wiring and plug for the lockup, they were in good shape, cleaned wires and connectors on both the lead and the tranny before plugging it in.
Two shops, including the source of the transmission , believe its a valve body or governor issue. The shop where it came from is trying to source out a transmission shop that will diagnose further.
What I want to avoid is any more damn flat bed rides to shops that don't have any idea how to deal with a C3 vette. At $100 a pop the tow-truck scene is getting old fast.
Either way, I think I'm going to spend tonight and tomorrow pulling it out.
It only take a few hours, but its getting old and the Girlfriend is losing patience with the situation, and me. Maybe I'll get lucky and the garage will burn down while I'm at work today. I'll buy her one of the new Mustang GTs and go back to the sportbikes, less restoration and far better performance level. 72Ray has got me ready to put on the leathers and get back out to Willow for some close quarters combat on the Kawasaki. I had thought I was slowing down enough to be happy with a low hp "cruiser", what I forgot about from my 1st generation Camaro days (13 total builds since age 17) was the near constant state of reparation or maintenance involved with American assembly-line vehicles. So instead of leisurely cruises, I have stressful repair/assembly marathons.
I read about cruises, shows, and other events and can only be envious of those that get to drive their car. We've been able to put a total of about 280 miles on the car since it was purchased in March. Invested over $5000 in that timeframe. I only been able to drive it about 70 of those miles. It ran great during the test drive, solid, smooth, no noises or anything. Stephen King's Christine was on the TV that morning, I should have picked on on the subtle Kharmic hint there.
I'd turn it over to a resto-shop if any of the local ones knew what the hell they were doing and didn't shove attitude at me when they find out I know more about Vettes, and what I want, than the usual schmoe that calls and just asks who to make the check out to.
Love vs. Hate
Does anyone win? Outside of MidAmerica and Corvette Central?
Readjusted, test-drove, still nothing.
The free wheeling after letting off the gas is weird, no drag at all.
Something is up. I'm headed out to check the governor gear, wait is that inside the tranny.... great.....
