Performance Upgrade L-48
Old Sep 13, 2005 | 09:39 AM
1975Stingray's Avatar
1975Stingray
Default Performance Upgrade L-48
I've been reseaching my performance upgrade for the 1975 L-48; I have a quick question, would it be worth it to upgrade the cam without a head and Carb change? If so what Cam would best suit my application? I have the original L-48 head and Q-Jet. I also plan on True Duals from Mid America and tuning the car using Lar's peck performance article. Any idea of new HP ratings? Any suggestions are welcomed! Thanks
Old Sep 13, 2005 | 09:54 AM
Ganey's Avatar
Ganey
Yes. You need to give trans. & rear gears for cam.
Old Sep 13, 2005 | 09:58 AM
1975Stingray
When you say Trans, what do you mean? I have an Auto, not sure of the final Rear end ratio. I would need to change the rear end?
Old Sep 13, 2005 | 10:17 AM
Fevre's Avatar
Fevre
You need to match your cam to your tranny and rear gear to get the most out of it, if you put too large a cam in it you will have a dog off the line that will take all the pleasure out of driving it.
What is your budget? If you can spend about $1500 you can get a top end kit that will have alum heads, alum intake and cam giving you a nice power upgrade.
Old Sep 13, 2005 | 10:26 AM
isosceles's Avatar
isosceles
Last year I added dynomax ceramic coated headers, MAD chambered dual 2.5 " exhaust and a Comp Magnum 270H cam. I used all this with the stock HEI and Qjet. The best improvement I saw was from 15.2 to 15.0 in the 1/4.
This year I borrowed the Holley HP750 carb off my 383. This got me down to 14.8. I replaced the HEI becuase my original one had a seized mecahnical advance. That got me down to 14.6. Not bad for a car with 3.36 gears, a tight converter and a factory rating of 15.9
All this on the original smog heads. I could get the car in the 13's easily with 3.70's and a higher stall converter. Low 13's if I throw in some decent heads, but I have my AR 383 waiting on the stand.
Old Sep 13, 2005 | 10:30 AM
isosceles's Avatar
isosceles
I learned the hard way (guys on the forum tried to warn me, but I'm hard headed ) that rear end ratio can give you the most bang for the buck in the acceleration department. If you have a 3.08 or 3.36 now, jumping up to a 3.70 will give you a nice seat of the pants feel, as long as you don't do a lot of highway driving without an OD tranny.
Old Sep 13, 2005 | 10:31 AM
1975Stingray
Looking to spend under a grand on performance and acheive about 225-250 RWHP. I'm not going to make the car a monster but want a little more get up a go; I would hate to have a Honda completely dust me on the street. I don't street race but don’t want to be embarrassed either!
Old Sep 13, 2005 | 10:32 AM
1975Stingray
Nice numbers for some bolt ons! The 383 will be fun I'm sure thanks for your comments!
Old Sep 13, 2005 | 10:35 AM
1975Stingray
I understand, I can be the same way; I just want to do the best bang but not hurt the overall drivablity of the car. What's a good street gear for both street and highway driving?
Old Sep 13, 2005 | 10:41 AM
Boofers's Avatar
Boofers
My 1977 L48 was originally 180hp at the flywheel. After I made these mods I dyno'd 240hp at the rear wheels (maybe 270hp at the flywheel)
- Comp Cams H268
- Hooker Comp headers
- Dual 2.5" exhaust, high flow cats, Magnaflow mufflers
- Weiand 8004 intake manifold
- Recurved stock distributor using Lars papers
- Retuned stock QJet using Lars papers
When I can afford it a set of heads should get me another 30rwhp or so. If you don't have all the money right now you can slowly upgrade your engine. For example do exhaust one year, intake & cam the next year, do heads a ways down the road, etc.
Good post you may want to read:
http://forums.corvetteforum.com/sho...d.php?t=1165420
Old Sep 13, 2005 | 10:47 AM
1975Stingray
- Comp Cams H268
Thanks; thats what I really want! Your mid pipe with Cats hows the sound? Can I ask where you purchased it?
Thanks!
Old Sep 13, 2005 | 12:11 PM
Chopper Larry's Avatar
Chopper Larry
For a grand only I would also stick with the rear gear swap; IMO, a cam change without head work, and exhaust upgrade won't do a whole lot..might even give you less performance. Think of the engine like a huge set of lungs (air in, and air out).
I have an L-48 and myson-in-law has an L-82 and I run stronger because I have a 3.70 gear and he has 3.08, or 3.36.
Old Sep 13, 2005 | 03:32 PM
flood's Avatar
flood
I changed my 75 L-48 rear gears and it made a big difference (3.70). At sea level I estimate I would run a low 15 or could squeak out a very high 14.
Up here at 5k feet ASL I ran a 15.8 at 90something, they say 1 sec drop at sea level is about normal. Thats the only performance mod at this time is just the gear swap.
Old Sep 13, 2005 | 03:33 PM
1975Stingray
How hard with that Swap in a Vette? At this time I've only done Mustangs!
Old Sep 13, 2005 | 11:11 PM
Alwyn678's Avatar
Alwyn678
The swap is Easy
Old Sep 13, 2005 | 11:54 PM
isosceles's Avatar
isosceles
Depends how fast you run and for how long. Down here in FL, if you're not doing 85 mph out on I75, you get passed by old ladies in mini-vans. I appreciated the 3.36's for the trips up I75 to the track. Once I got the OD tranny I wish I had stayed with the 3.70's when they needed replacing. Driving for 1 hour at 3500 RPM just to do 75 wasn't fun at the time.
Now I'm going to trailer the car to the track and I don't even need the OD tranny!
Old Sep 14, 2005 | 09:38 AM
1975Stingray
Any suggestions on where to get a nice set of gears? How about 3.55?
To Performance Upgrade L-48
Old Sep 14, 2005 | 12:58 PM
James B's Avatar
James B
Old Sep 14, 2005 | 09:20 PM
jeaux's Avatar
jeaux
Hey Boofers what post are you refering to the link didn't work for me?
Old Sep 15, 2005 | 12:05 AM
Mefixum's Avatar
Mefixum
Cruising
Richmond gears makes the gears you're looking for. You have to buy them through a distributor though. I used ZIPCORVETTE for my 3.70s. Nice punch - nice price!
