What do I need - Suspension
Old Sep 13, 2005 | 03:58 PM
Nate '69's Avatar
Nate '69
Default What do I need - Suspension
PROBLEMS: bad understeer, feels nose heavy, rear breaks loose easily on curves, bad wheel hop
CURRENT SUSPENSION:
front springs unknown, new looking, maybe 460lbs
rear steel 5 leaf spring
new rubber bushings all around
front 3/4 sway bar with poly bushings
KYB's
cross member reinforce aluminum plates
front A arm spreader bar
vbp smart struts (stock bracket)
front tires nitto 555 255/40/17
rear tires nitto 555r 285/35/18
*no room for rear sway bar due to wheels, exhaust, fuel pumps etc..
*everything that can be aluminum in the engine compartment is except block..
I want to lower it 1" all around but the half shafts are already parallel to the ground.
(1969 vette, 496 engine, ROD tranny)
What changes should I try? Thanks
Old Sep 13, 2005 | 04:52 PM
Fevre's Avatar
Fevre
Get the 550 springs, the 460 made my vette sit up high like a 4x4 but i do have a SB with alum heads, intake, headers, etc.
Old Sep 13, 2005 | 04:57 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
From what you explained, it seems that you have an oversteer problem.
1st thing I noticed on your list is the spring rates. SB front springs and you have a really stiff rear spring. BB front springs will lower the front and match the rear spring much better.
Old Sep 13, 2005 | 05:00 PM
Nate '69's Avatar
Nate '69
How can I confirm the front spring rate? What should the ride height in front be with the BB springs?
Is another option to install a 1 1/8" front bar to decrease oversteer?
Thx,
Old Sep 13, 2005 | 09:55 PM
mandm1200's Avatar
mandm1200
Originally Posted by Nate '69
How can I confirm the front spring rate? Thx,
About the only way I know to check spring rate is to take the spring to a shop that can test it. I don't think the average garage will have the tester, but a bonafide race shop will. They do not rely on manufacture specs when putting springs on a true race car, they need to know the spring rate so they can duplicate a setup or make changes based on data not on a spec sheet.
Old Sep 13, 2005 | 10:05 PM
big_G's Avatar
big_G
Please put a 1-1/8 inch front sway bar in. It should correcet your oversteer nicely. The back spring is in essence acts as a sway bar. (Oversteer is back breaking loose before front)
Old Sep 14, 2005 | 12:09 AM
flynhi's Avatar
flynhi
Ditto Big G.
Also, with your power and expected use, I'd recommend more substantial shocks like Bilstein Sports.
With your ROD, you'll probably be pending some time in triple digits where a slight rake will decrease front end lift. Use the VB shorter front springs and leave the rear where it is.
I'd also give attention to the steering (rag joint, steering box, tie rod ends, idler arm) to keep all that power going where you want it.
Old Sep 14, 2005 | 11:52 AM
Nate '69's Avatar
Nate '69
I said understeer because in a slow turn the car doesn't "want" to turn but turning at a higher speed the rear breaks loose.
So it seems I have understeer at low speed and at higher speed I have oversteer .... does that make sense?
I'm waiting on the PO trying to find out the front spring rate and alignment specs. This vette was setup for drag so alignment could be part of this too.
Old Sep 14, 2005 | 01:09 PM
76stingracer's Avatar
76stingracer
Fix the spring issue as stated above and then take the car to an alignment shop that will put the VB alignment specs on the car for you (not some stored numbers the shop computer has) or as close to the VB specs as they can. Remembering the alignment numbers should equal side to side. Most shops will not make them equal just close.
Old Sep 14, 2005 | 06:36 PM
68427's Avatar
68427
Your front sway bar is too small for those spring rates. Measure your front spring wire diameter, if it is less than 3/4", then you likely have more spring rate in the rear than in the front. I use a 5-leaf in back, it is one stiff SOB. Since you are experiencing oversteer and you do not have a rear bar, you should either increase front roll stiffness with a bigger bar or springs or both or reduce rear roll stiffness with a softer rear spring. Your half-shafts should angle slightly down towards the wheel so when you corner and the car goes into roll, you don't toe-out in the rear (causes bump oversteer). If you want to run a low ride height and have it handle, you'll need to raise the differential in the chassis or use smaller diameter rear tires. Good luck and go faster.
To What do I need - Suspension
