Where is my Tach Filter?
Old Sep 13, 2005 | 08:15 PM
KALAWAY's Avatar
KALAWAY
Default Where is my Tach Filter?
I'm ready to tackle the tach repair job and want to locate and test the tach filter before I purchase a new tach circuit board. Can someone tell me where it is using the attached picture.
http://img.villagephotos.com/p/2005-...TachFilter.JPG
Old Sep 13, 2005 | 10:23 PM
Kilroy1024's Avatar
Kilroy1024
Default Where's the Tach Filter
Found a picture of a Tach Filter
I think it looks like this
http://www.madvet.com/shop?frame=1.140.5902
Old Sep 13, 2005 | 10:36 PM
Kilroy1024's Avatar
Kilroy1024
Plenty of tach filter info on this thread. (and others)
http://forums.corvetteforum.com/showthread.php?t=913235
Quote from that thread: The filter is located at the rear of the intake manifold, bolted to one of the rear bolts, drivers side. (at least on mine) It looks like a typical round metal can filter cap with a wire at each end and a tab welded to the side which is used as the mounting point.
There is some debate as to the purpose of the filter, Some say its for protection, I believe it simply for noise filtering. Some people are running with no filter, no problems. If you replace the filter with a 10K ohm resistor, and the tach still doesn't work, its probably not the filter.
Old Sep 14, 2005 | 01:08 AM
Star79's Avatar
Star79
It's supposed to be where kilroy says, looks to be not there in your pics (black X below, that's where it is on my car). Maybe someone moved it, or got rid of it completely. It's a little silver cylinder the size and shape of an M-80 (if you remember your fireworks from highschool )
If you follow the lead from the BLACK clip on the dist (purple arrow below), that's the tach signal lead. That wire goes to the filter, then goes to the tach.
To Where is my Tach Filter?
