BBC Cam suggestions .. ?
Old Sep 14, 2005 | 11:53 PM
carbster09's Avatar
carbster09
Default BBC Cam suggestions .. ?
I am looking to rebuild my LS-5. I'll have ported stock Oval 71 heads, stage II or III. Ported intake and exhaust manifolds. A reworked Q-jet, with maybe ~ 850 cfm. All this with a 3.70 rear and a 4 speed. I might go with a 4.25" stroker crank, depending on $$.
Any ideas on a Hyd. roller cam? I like the Voodoo line and a few crower and crane grinds.
carbster
Old Sep 15, 2005 | 07:26 AM
GOSFAST's Avatar
GOSFAST
Default 1972 LS5 BB Resto
We're in the process of doing the (same) engine for a '72 Chevelle convertible. It'll be a 4 speed car. We've made the engine into a 496". We expect to see somewhere between 475/500HP with power brakes being functional. The engine is being assembled at this time and scheduled for the dyno in 2 weeks. We chose a Comp retro-hydraulic for a nitrous application due to the fact of the small exhaust valves and add'l exhaust duration. This will be a first time build on this platform. The cam we chose is the Comp Cams 11-409-8 (224/236 x .540/.550 x 113LS). We'll find out if we're right. We cant use any vacuum cans due to originiality. The engine will be tested with all the customer's "right" components, oval ports, cast intake, Q-jet, and cast exh. manifolds.
Thanks, Gary in N.Y.
P.S. The engine will have 9.75:1 C.R., 2.190" intakes(which were preinstalled, we would have left the 2.065"s in place), 1.720" exhausts, and a set of 1320 Comp pro-magnum rockers.
Old Sep 15, 2005 | 09:09 AM
carbster09's Avatar
carbster09
Default same story..
I am looking to build pretty much the same type of motor as your 72 Chevelle.
What crank did you use and why?
I like the spec on that cam. Is it a roller? My parts will be ported and should flow good. Therefore I believe that cam will work well. What was the duration @ 0"?
My builder will only use a roller cam on a BBC!
carbster
Old Sep 15, 2005 | 04:48 PM
Techno's Avatar
Techno
Your asking for cam advice but not giving the use.
What do you want out of it?
I have a non roller hydralic cam 11-313-4 .544" lift 276/284 adv. duration.
This is a mid to lower mid cam. around 230s/240s
I did put in a torquer rv cam and it was too much. Broke traction around corners way too easily.
Bottom feeder cam.
carbster09 Although I like roller cams I don't like the price. If your serious about the builder I would get a different one. Any builder should be building your engine the way you want.
Now if this guy is so set on roller cams why are you asking here and not using his knowledge?
Old Sep 15, 2005 | 06:15 PM
RatRacer's Avatar
RatRacer
If you will be running around 9:1 compression, the Comp Cams XR282HR hydraulic roller looks like a good choice.
I have a modified LS-5 and with our heads, more lift than .520 and you'll need to flycut the pistons and cut the valve guides down.
Old Sep 15, 2005 | 06:29 PM
carbster09's Avatar
carbster09
Default Mid range power with good bottom end
I plan on running 9.5 CR. These cams seem to be quite good. I just wanted to ask if anyone has experience with putting various cams. We all have a favorite. I am just looking for great mid range power with enough low end grunt. Let's face stock is a little "sorry".
There are a few Lunati/Voodoo profiles that I liked. Hence I figured I would ask if anyone has used them. The guy that will be putting it all together does mostly "stock" or close to stock rebuilds as its a corvette only shop. However the shop has had a number of cam failures, therefore the roller cams are perferred. Not a problem for me as I like the idea of getting rid of all of that friction etc.
carbster
Old Sep 15, 2005 | 08:04 PM
Techno's Avatar
Techno
My cam is pretty much what your looking at. The only thing I don't like is it seems to run out of steam at 3.5 grand? A bit below? Gears are diff and your heads are probably better.
Up to that its pulling pretty good its a relative thing to some extent. It was pulling and now its pulling less.
Still this is like 98% of my driving and even horsing the gears on an on ramp I'm over the speed limit anyway.
Its enough to skip 2nd and 3rd in most street driving. I can almost do 35 in 4th since 35 don't really exist in the real world....
With your heads and rollers I think it will be much more on the higher end & mid.
Old Sep 15, 2005 | 09:39 PM
Brettmc's Avatar
Brettmc
Run. Very fast and very far.....
Brett
Old Sep 15, 2005 | 09:45 PM
guvnerwl's Avatar
guvnerwl
St. Jude Contributor
Crane custom hyd.roller
256/264 duration at .050"
.632"/.632" lift with 1.7 rockers
114 degree lobe separation
Jesel SS shaft rocker system, BBC 1.7 ratio
Callies Pro Magnum 4.250” crankshaft
peaks at 6300 rpm
Old Sep 15, 2005 | 10:19 PM
RatRacer's Avatar
RatRacer
carbster
A roller is definitely the way to go. High lift, short duration flat tappet hydraulic cams don't live long.
Old Sep 15, 2005 | 10:21 PM
RatRacer's Avatar
RatRacer
peaks at 6300 rpm
You must be running more than 9.5:1 compression. That's a lot of cam.
To BBC Cam suggestions .. ?
