Which leaf spring should I use? (pic)
http://wopr.myftp.biz/pics/8%20Corvette/leafsprings.jpg
includes 7 leaf springs. The later C3s used a 2 1/2" wide spring.
With performance suspension options, they used the 2 1/4" 7 leaf
spring with two metal spacers. Pic:
http://www.zip-products.com/Zip/prod...852067B8963160
They look like the same # of leafs to me. I think the top one looks fine,
but it's hard to tell until the car is riding on it.
here are a few more: http://wopr.myftp.biz/pics/8%20Corve...afsprings2.jpg
http://wopr.myftp.biz/pics/8%20Corve...afsprings3.jpg
I think you may have the suspension upgrade option(Gymkhana) in your vette. If you have a rear sway bar then you did...it also came with the stonger 2.5" spring. Stick with the original and use good shocks.
Spacers in my link above.
78-79 FE7 (Gymkhana) used the 2.25" 7 leaf.
80-82 FE7 used a stronger 2.5" 9 leaf.
The 7 leaf spring is definitely stiffer than the 9.
I don't know what's up with those 'straight' leafs, but they are definitely suspicious.
A new 7 leaf steel spring is 'only' about $100. You won't want to tear
it all apart and reinstall once everything is painted and bolted back together.
A spring shop should be able to test the spring and even re-arch
the leafs - if needed. This should be cheaper than a new spring.
A small rear sway bar can help with cornering without sacrificing ride.
Too big a rear bar - and you will tend to slide out on corners.
Of course, this could be added later if wanted.
Good Luck.. Here is a link to VBP.. FYI, they have GP's from time to time as well.
http://www.vbandp.com/SearchResult.aspx?CategoryID=171
I've seen replacement springs at Ecklers site that look just like it but don't know the stiffness.
The car did not have a sway bar on it and I will be happy enough with the cornering perfomance the way it is but I want to make it have better performance at the strip so I plan on using the longer bolt kit to lower it.
The main thing is I want to know which one would be better at the strip.
