Anyone using a transmission cooler separate from the radiator?
My stock radiator has a small leak. Instead of repairing or replacing it with another stock radiator, I think I'm going to try and get a 19x31 aluminum radiator (Griffin or Northern probably). These universal radiators do not come with the automatic transmission coolers. So, that means I need to find a separate transmission cooler. Anyone have some ideas?
Thanks, do you have a recommendation on the minimum size I should look for? I am browsing ebay and I see many different sizes. I'm assuming bigger is better. I'll keep in mind about the round tube types.
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
cars needs.
You don;t want your trans to run tooooooo COOL
Location: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I've seldom seen any Vette run cool anything under the hood. I run seperate trans coolers on both my L82 and LS6, just go to a auto store and ask for one. Mine are 1/2 the size of my rad and work perfect without any trans issues. I run headers near the transmission so for me I picked bigger to displace the heat made by the tranny and headers been so close to it. My 0.2
You can't run a auto tranny too cold, unless you winter drive in Minnesota/similar....impossible....
I would use a larger size a/c condensor/evaporator from a window a/c unit, fab up some mounting brackets so it's about 1/2 inch from the next heat surface and call it quits....
gotta be about 3' sq of area...hopefully with two parallel 3/8 tubes....
GENE
GENE
Junkyard tranny cooler out of a Crown Vic police car, approx 12" x 18", 20 bucks. You can just see it in this pic. New ones from B&M etc are 50-100 depending on size.
1 Post
Originally Posted by turtlevette
i tried using the AC radiator as a tranny cooler and the turbo 400 shi+ the bed days later.
maybe there was some crap in it.
For what I was told by one trans co.
