I am putting this engine together and have installed the new Pioneer harmonic balancer. I don't understand why the line on the harmonic balancer is not lined up with the timing marks on the timing chain cover. My #1 piston is all the way up- see pic. --newbie here though.
Have you confirmed the TDC #1 is correct by using the manual method?
Put a feeler in #1 plug hole
Turn clockwise and mark when it hits (gently)
Turn counter clockwise and mark when it hits (gently)
Split the difference should be TDC
I don't think the piston is at TDC when it's "all the way up".......that is why you turn the crank until it hits the feeler guage (if the heads were on) and then reverse the rotation instead of continuing, because the piston travels up a bit more before going back down.
Also, to those trying to help, notice the heads are off.
I know that some sbc balancers are keyed slightly differently. I believe it was 10 degrees different. This looks like just about ten degrees off to me.
Where on the balancer do you mark these 2 positions?
thanks
The feeler is anything that will not damage the piston or sparkplug hole and is inserted in plug hole. Use something that wont break or come apart too.
As you slowly rotate crank by hand clockwise you are feeling for the piston as it rises in the cylinder. (Number One Cylinder) When it no longer moves up STOP and put a pencil mark on the balancer in line with, ah say the timing tab. Next slowly rotate crank in opposite direction until you feel the piston start to move. STOP and put another pencil mark on the balancer. Half way between these marks is TDC.
Obviously this is much easier with the head off and you can just watch the piston. You can also watch the valve action and tell which is the firing stroke and check distributer too.
I once made a sparkplug hole/dial indicator adapter to use as a probe when I messed with motorcycles. Made magneto/point setting a snap.
Good luck
My heads are off so would this same theory apply?
Do you mark the 2 places on both ends on the gauge on the balancer so that directly between the 2 is the 0 degree mark?
Just feel of the #1 piston as she comes up while rotating crank clockwise (same direction engine runs) . When she stops moving up put a mark on the harmonic balancer using the timing tab as a pencil guide.
Slowly rotate backwards and when piston just moves put another mark on balancer using the same tab as a guide. TDC is halfway between these two marks..... the piston needs to be on the firing stroke when doing this, not the exhaust stroke, if you are checking dist. too.
If the factory mark on balancer is somewhere other than zero degrees it should be indicated so in some way... I think....check with your supplier.
Also, do you know for sure you put timing chain on in correct relation to crank and cam? If not now is a good time to correct it.
With the heads off, I would use a dial indicator and magnetic base to establish TDC.
It is quite likely your new damper is made for an 86-91 sbc ... their TDC mark is about 40° to left of keyway centerline ... their timing tab(actually sight-tube-affair) is also about 40° to left ... right about where your TDC mark is in your pic.
69-85 dampers' TDC mark is 10° to left of keyway centerline.
Pre-69 dampers' TDC mark is 2° to left of keyway centerline.
Again, I'd say you got a damper for a late model (86-91).
I did what was suggested above by marking 2 places on the balancer using the same point of reference on the side (end) of the timing tab. I placed a line exactly halfway between these 2 marks- which should be TDC. Then I moved the new line in between the other 2 to the same point of reference on the side of the timing tab. Since the factory line on my balancer is not at the 0 degree point I marked another line at the 0 degree mark on the balancer. Is this my correct TDC now?
