How do you close pop up lights
Old Sep 16, 2005 | 11:23 PM
cal camara's Avatar
cal camara
Default How do you close pop up lights
I just purchase a 72 vert, that has been sitting for years. The lights are up and I want to put them down. The owners manual tells me how to put them up but it says to see a dealer to put them down. Does anyone know how to get them down.
cal
Old Sep 16, 2005 | 11:30 PM
big_G's Avatar
big_G
Reach into the lower opening below the bumper under either light. Find the pivot where the springs come togeather, grab it and pull down. Might have to try different angles till you get it. About 5 pounds of pull will do it.
Old Sep 17, 2005 | 04:05 AM
c3 in hawaii's Avatar
c3 in hawaii
I had the same problem with my '78 .
Old Sep 17, 2005 | 08:43 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
reach up between the grilles and feel around for a bolt with threads on it and the headlights should beginn to lower.
Old Sep 17, 2005 | 09:19 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
You can also grab one of the springs and pull down on it. That should work, too.
Old Sep 19, 2005 | 12:31 AM
Langadorf's Avatar
Langadorf
For a while, after an engine rebuild, I didn't bother hooking up the vacuum lines to the lights. Everytime I drove it at night, I'd have to manually pull up the lights. The next day, I'd have to reach under and pull them back down. Took a while at first, but can do it blindfolded now.
Old Sep 19, 2005 | 01:06 PM
68/70Vette's Avatar
68/70Vette
To pull them down manually, it's probably help to disconnect the vacuum lines attached to the can-shapped actuators.
I've moved mine up and down manually many times. Very easy.
But be a little careful. The springs are very strong and be careful not to get your finger in the pivot stop area.
To How do you close pop up lights
