head lights will not go down
Old Sep 17, 2005 | 02:57 AM
cab's Avatar
cab
Default head lights will not go down
for some reason the headlights will not go down when the switch is off and the engine is running. i must have another christine. where do i start i am about to give up fix one thing then another i just want to ride and enjoy. please help.
Old Sep 17, 2005 | 06:08 AM
grybdn's Avatar
grybdn
did you try the override switch under the steering wheel?
Old Sep 17, 2005 | 08:08 AM
78pacer's Avatar
78pacer
Replace the small inline filter behind your carb. 2 hoses in, one out
Old Sep 17, 2005 | 09:19 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Small **** mounted under the dash beneath the steering wheel. Push that up, it's the override to open the headlights. If that's not the problem, then...
http://209.183.231.72/corvette-101/vacuum.htm
To head lights will not go down
