Finally, 15K miles later
I replaced the OEM HEI dist with a Mallory Billet, last summer, cleaning up the ignition system after dyno tuning showed random misfires at high RPM.
Interesting note: I' had become to be used to the noise of the forged pistons on cold startup, banging around with Diesel-like sounds for the first mile or so when cold (especially if not driven for a week or so).
Now, 15K miles later, even that noise has calmed down and I have to listen for it to be aware of it any more. I'm terrifically pleased with the motor these days and it's become more and more of a joy to drive.
Don't know why this motor was so much different than others I've put together but the bottom line is, I LOVE IT!
Now just two issues left: Fuel smell and the Qjet's flat spot on takeoff that doesnt' wanna go away.
Congrats on working things out. Those 33 extra cubes with forged parts give it BB class for alot less cash. A stroker would be fun to build and install - some day.Its only fun when things go right. But we all make a few left turns too.
Did u try a new charcoal EVC with a non-vented gas cap? Check that vapor separator vlv working and the line clear all the way to the correct ported vac port?
cardo0
I did pull the tank down and the smell is not from that area. Hoses were good and there was no vapor seperator on the tank to be bad. I did not yet pull the evap cannister, but I have, over and over again, felt around that area for moisture and/or bad hoses. Everything down in that fender looks and feels like new, except for my hand when it's in there!
What i'm saying Paul is that if u don't have a separator u need to evaluate what u really have in that system. Vented or unvented cap? No liquid separator - is the EVC connected to the tank and correctly connected to the carb? A EVC without a connection to the tank and a liquid separator in between will then only take vapor from the carb fuel bowl. The fuel tank needs to vent somewhere - thats what the '73 & later EVC systems where designed for.
Well i hope this helps and good luck. Sorry i know nothing 'bout flat spots.
cardo0
