Ignition Problem
Old Sep 18, 2005 | 05:24 PM
nastee383's Avatar
nastee383
Default Ignition Problem
Well I still can't get my motor fired but I THINK I've narrowed it down to an ignition problem. I said before I had spark and I do...sometimes. I rechecked for spark on the no.1 and 2 plugs. Number one would fire sometimes and other times nothing. No. 2 never fired. This is my setup: HEI, ACCEL 300+ box(new), ACCEL375+digital module(new), ACCEL U-groove shorty plugs(new), ACCEL 300+ plug wires(new), Optima Red Top battery(fairly new). This is what I have done so far to chase down the problem:
1) checked for 12 volts at the ignition connection, there was 12.
2) checked for spark on several plugs, got it sometimes, on one plug.
3) bypassed the ignition box/module, no difference.
4) installed the distributor from the VETTE which I KNOW works, no difference.
5) rechecked distributor/rotor position at TDC, comp stroke
6) charged the battery prior to attempting to start the vehicle. Battery showed 12.7 volts.
This is a non-computer controlled vehicle. I'm going Any thoughts on what the prob could be??
Old Sep 18, 2005 | 06:00 PM
big_G's Avatar
big_G
Coil?
Old Sep 18, 2005 | 06:24 PM
nastee383's Avatar
nastee383
Originally Posted by big_G
Coil?
When I switched distributors there was no difference. I put the distributor back in the Vette and drove it that afternoon, so I know it was functional.
Old Sep 19, 2005 | 12:17 PM
nastee383's Avatar
nastee383
Anyone else? Is it just me or do my requests for help/advice get far fewer responses than most others?
Old Sep 20, 2005 | 10:06 PM
nastee383's Avatar
nastee383
I guess it isn't just me.
Old Sep 20, 2005 | 10:19 PM
David Ey's Avatar
David Ey
yep, it's you. nobody likes you anymore.
Well, just kidding.......It sounds like your starter is sucking all the juce and not letting the coil get enough. I think there is a wire on your starter to the ingn. that is supposed to prevent this but I don't have a diagram to look at. Maybe someone else can help.
Old Sep 20, 2005 | 10:23 PM
Brettmc's Avatar
Brettmc
That's because it's a tough problem! Ok, you replaced the dist. with the unit from your vette, which is a known good dist. That leaves just a couple of possibilties. (1) the voltage supply & (2) the plug wires. (1) maybe you've got an intermittent ground on the supply. Can you rig a different wire for that? (2) take the plug wires off the vette and use the vette dist. too. Oh, how about a faulty ign. switch? That might cause intermittent fire too.
Brett
Old Sep 20, 2005 | 10:24 PM
Brettmc's Avatar
Brettmc
OR, maybe you wiped a lobe on your cam....
Brett
Old Sep 20, 2005 | 10:28 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Hmmm.. I posted about my hesitation issue 2 days ago.. I ttt'd once and didn't get a single response.. With other words.. You aren't alone...
As for your issue.. I don't know what to tell you....
I'd probably try to borrow a friends ignition or get a HEI from the junk yard for $30 to check if it would work with another ignition..
Old Sep 20, 2005 | 10:33 PM
David Ey's Avatar
David Ey
you are not charging your coil i bet ya
Old Sep 21, 2005 | 10:33 AM
69vettester's Avatar
69vettester
Coils dont fail very often but borrow a good coil hook it up and test. Maybe thats all it is?
Old Sep 21, 2005 | 11:56 AM
David Ey's Avatar
David Ey
Correct, however his problem sounds like the power TO the coil is mostly missing not that his coil is bad. but i am just guessing
Old Sep 21, 2005 | 11:17 PM
nastee383's Avatar
nastee383
I've done some internet research since the original post and I've learned alot about how ignitions work and how other components such as the ignition switch can play a role in a "weak" ignition, etc.
When I put the distributor from the Vette in there and it didn't change, that eliminated alot of possibilities, such as the coil, module. I have some tests to do based on what I've read in some tech articles. I just hope I don't hurt myself because I'm no electrician. I already fried a fusible link, never seen one burn up before. It looked like a smoke bomb. That's been repaired. Now for the hard part.
And lastly, I do appreciate the responses I get. I know sometimes I don't respond to posts because it seems the person has already done everything I know to tell them or someone else has already suggested what I was going to. I was just hoping someone had maybe experienced the same problem and had a solution. Sometimes it works and sometimes it doesn't. I'm still ahead of the game, I've received alot of good info from the forum.
Old Sep 21, 2005 | 11:21 PM
Brettmc's Avatar
Brettmc
Try some of the forums over at www.chevytalk.org.
Old Sep 22, 2005 | 06:54 AM
KALAWAY's Avatar
KALAWAY
Just recently had a "spark" problem and turned out it was a bad ignition module. Replaced it and fired right up.
Old Sep 23, 2005 | 09:59 PM
nastee383's Avatar
nastee383
If you have 12 volts at the ignition coil connection (pink wire) with the switch on and it drops to 10.5 during cranking is that normal? Or should it remain around 12? I'm thinking as someone suggested that maybe the starter is drawing too much current during cranking. It is making a little noise during cranking.
Old Sep 23, 2005 | 10:02 PM
big_G's Avatar
big_G
10.5v. is fine
To Ignition Problem
Old Sep 24, 2005 | 04:22 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Hard to see the problem from here in CA.
I would really like to help nastee but u have an ignition box i'm not familair with. Even though my MSD sytem has a installation & trouble guide and even if u were using MSD it would take forever to compare notes over the internet. But i do know that u can run that HEI with only 1 wire and bypass that box - just to run it. As far as testing spark if u hold the coil wire (dist end) within 1/8" of exposed metal on engine/block (vlv cover) a bright blue spark is a good one - other colors of sparks ain't.
Again i apologise but to troubleshoot a bad coil and/or dist module would be a large task to do here. Now Dr. Jacobs books on ignitions will take care of that and i just bought his latest from Summit for $20 - Optimizing Your Ignition. Easy to locate and can read just the part sections that u want to test.
Sorry to hear ur troubles but u know there's always unexpected delays when starting up a custom engine let alone a swap. cardo0
Old Sep 24, 2005 | 01:28 PM
cardo0's Avatar
cardo0
Default Oooopps.
Originally Posted by cardo0
... As far as testing spark if u hold the coil wire (dist end) within 1/8" of exposed metal on engine/block (vlv cover) a bright blue spark is a good one - other colors of sparks ain't.
Oh that's right, theres no coil wire on an HEI. Well then try a plug wire (any) and hold the plug terminal to the block/metal.
:o cardo0
Old Sep 24, 2005 | 04:56 PM
nastee383's Avatar
nastee383
I did bypass the ignition box and attempted to start it just on the HEI and there was no change. I've been doing alot of reading on ignitions lately. This book sounds like it could be a good source of info. I may try it.
I took my starter off to examine it and something is fragged on the inside even though it still turns the motor over. There is grease from inside slung all around the area of the starter gear. I would take it apart to see what happened but it's under warranty and the paperwork said if you disassemble it, the warranty is void. Maybe there's a connection between the starter and the "no start" problem.
