firberglass adhesive?
Old Sep 22, 2005 | 08:41 AM
rrent's Avatar
rrent
Default firberglass adhesive?
I just noticed the bottom of the outter door skin on my '77 is loose......
Is there an adhesive I could use to reattach this? Or will I needed to bond it with fiberglass? If fiberglass, any suggestions on which products are good better best - cheap moderately priced or expensive as heck?
It doesn't seem to be a problem just a little noisey when I close the door.
Old Sep 22, 2005 | 05:42 PM
DVG73's Avatar
DVG73
If you just need to stick the panels back together, 3M 8115 dual component epoxy works very well. Problem with that is you gotta buy the dispensing gun $$$. You could probably work some kitty hair or fiberglass panel adhesive in the cracks and clamp and it should hold it and those materails are not real expensive.
Old Sep 22, 2005 | 05:54 PM
big_G's Avatar
big_G
Or you could get some J-B weld. It is a small quantity for a small job.
Old Sep 22, 2005 | 07:05 PM
rrent's Avatar
rrent
After checking it is fiberglass rather than the firberglass as the title indicated
sounds like you guys think any good quaility two part epoxy will work?
Old Sep 22, 2005 | 08:29 PM
mandm1200's Avatar
mandm1200
Fiberglass, firberglass. fibbergraass, ect.. They are are made the same from the same material. The difference is how fast you type.
Old Sep 23, 2005 | 01:26 AM
lowbuck72's Avatar
lowbuck72
Bondo makes a product called Bondo Glass. It's pretty much the same as factory bonding adhesive, and you'll get a quart for less than the price of 3 tubes of JB weld,which is great stuff, but save it for the "impossible" repairs.
Old Sep 23, 2005 | 03:56 AM
low1quart's Avatar
low1quart
2nd Gear
When I took mine apart, I had to clean the two sided tape off before I could replaced it back again with 3M two sided mounting tape
Old Sep 23, 2005 | 06:21 AM
Eric R's Avatar
Eric R
I was thinking Urethane, the same stuff that holds your windshield in the car.
To firberglass adhesive?
