Is it feasible to flare 3/8 stainless fuel line tubing with a home flaring kit or is the stainless material too hard to do this? I have a piece that needs to be shortened but I want to know if any one has done this before I try it and screw it up. Thanks...
I have done it, but I have a Hydralic flaring tool. I think the home tubing flare tool might not be powerful enough to make the flares and also get a good seal.
Try you auto part supplier(o'reilly auto). they might be able to do it, or take it to a car builder near you, surely they could get you in the right direction.
S.S. work hardens so when you cut it do not us a tubing cutter but use a cut off wheel and it will flare much easier.
From: Las Vegas - Just stop perpetuating myths please.
The flare kit usually says what will work in the instructions.
U can cut the tubing with a hacksaw and file it square but a regular tubing cutter will harden the end. Also use a scraper to debur the end inside and out. U should try to find some scrap for practice as making the first bend is at a critical hieght for the double flare. I like to use lars trick eyeing the die thickness for a gauge.
I also need a table vise to clamp the tubing vise just for carbon steel - SS would need greater force. U may need a cheeter bar to help with the turning.
Myself i would not mess with the temper - though normalizing is common practice on aircraft chrom-moly.
Hope this can help. cardo0
Reason: clarification
