What do you use for Jack stands???
Old Sep 24, 2005 | 05:56 PM
norvalwilhelm's Avatar
norvalwilhelm
Default What do you use for Jack stands???
How do you guys support your car for the winter if you are working under it. My son didn’t like me using Jack stands so he made me one front cradle and 2 back stands. They are super duty and powder coated black.
Guess he doesn’t want the car falling down on me.
Heavy rubber is used on the cradle so it doesn’t mark the crossmember
He made me 2 of these for the back. Heavy plates on the bottom to prevent tipping, a smaller plate on the top and very sturdy tubing.
Old Sep 24, 2005 | 06:19 PM
danboback's Avatar
danboback
wow! How much would it set? Those look really heavy duty!
Old Sep 24, 2005 | 06:27 PM
rosslato's Avatar
rosslato
a very wise and caring kid u got there. he did a great job on em. those certainly look sturdy, those could support a train. like your carpeting, makes working on the vette so comfortable and keeps the moisture off the frame
Old Sep 24, 2005 | 06:41 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Wow. Those look pretty darn nice.
My setup is sturdy enough but nothing like that. I have four jackstands that could support a truck, hardly ever do I use all 4 at once though. I usually run the front up on some Rhino ramps and jack the rear up to match.
Old Sep 24, 2005 | 07:10 PM
GTR1999's Avatar
GTR1999
Nice work there Norval, I guess the "apple" didn't fall far now did it!
How tall are those and how did you get the car up that high?
I had my 72 up on 20 ton truck jacks for 6 years straight,removed all the drivetrain and suspension and installed it back with them.
Gary
Old Sep 24, 2005 | 07:11 PM
Twin_Turbo's Avatar
Twin_Turbo
those are nice, very sturdy looking.
This gave me an idea...how about air jacks under the car
Old Sep 24, 2005 | 08:14 PM
norvalwilhelm
Gary
My son is a great fabricater. He is skilled with the plasma cutter, mig welding and just about everything else. He has taught me alot over the years and I hope I did him. While no mechanic he does have a night business repairing cars and makes a good almount of extra money evenings.
They are about 26 inches high.
How do I get it up that high? With a set of 3 ton jacks, One end, part way, then the other and back to the front again for the final lift.
I also sometimes get my son over and we use 4 3 ton floor jacks and lift it at 4 corners at once and slowly lower it.
The car really sits well and steady on this setup. I give him some idea, he takes some measurements and drops me off something the next day.
He is a good man.
Old Sep 24, 2005 | 08:15 PM
norvalwilhelm
Air jacks would be fine but it is hard to beat my set. Steve did a fantastic job
Old Sep 24, 2005 | 08:17 PM
norvalwilhelm
My shop is 2 levels. Both drive in. This is the upper level with heavy heavy wood flooring. Each level is 750 square feet. The lower is heated in the winter all the time and this upper is heated part time. The floors are well covered so when I have to dirty area I just throw the rug out. They are about 4 or 5 levels thick so in the winter it is really nice working in the shop. Never damp, never get condensation.
Old Sep 24, 2005 | 08:18 PM
norvalwilhelm
It's not the cost so much as the shipping. They are not lite. No consideration for weight?? Have to drill them full of holes
Old Sep 24, 2005 | 08:28 PM
greyghost79's Avatar
greyghost79
i usually just lay beside the car, lift it up with one arm and work under it with the other. they're real light ya know. being fiberglass and all.
Old Sep 24, 2005 | 08:30 PM
norvalwilhelm
Maybe you could help me with my horse shoeing. You could hold the horse in your lap while I nail the shoes on. Sure would save my back
Old Sep 24, 2005 | 09:40 PM
Techno's Avatar
Techno
Now I know how to work on one without getting the back pain from stooping.
Looking at the picture again I noticed some of the special stuff.
DAMN! your sway bar is bigger than the torsion bars in my old 69 eldorado and that was 3,000 lbs. Although there were two bars. Is that an antisway bar or a replacement for your spring?
Old Sep 24, 2005 | 10:52 PM
jdmick's Avatar
jdmick
I was teaching my 9 year old how to weld the other day. He'll be OK once he quits jumping back when the sparks start to fly. It may be a while until he builds me much of anything.
Old Sep 25, 2005 | 04:03 AM
groovyjay's Avatar
groovyjay
Not a bad idea...
Old Sep 25, 2005 | 04:14 AM
Twin_Turbo's Avatar
Twin_Turbo
I had actually been looking at the AP airjacks..they're not that expensive even (watch load rating, you need the heavy duty ones)
Old Sep 25, 2005 | 10:59 AM
norvalwilhelm
That is a 1 1/4 inch sway bar with bearings, not the rubber of poly type. I also have a matching 1 1/4 inch on the back.
It does show the front and back coilovers as well.
If you look at my tie rod sleeves you will notice them longer and mounted alot lower on the outside then stock. This is required for zero bump steer.
To What do you use for Jack stands???
Old Sep 25, 2005 | 12:39 PM
Maymyvetteliveforevr's Avatar
Excellent Job norvalwilhelm.
My 16 year old wants me to teach him to tig weld, but I need to get better at it myself first.
Frank
Old Sep 25, 2005 | 06:03 PM
BerniesVette's Avatar
BerniesVette
Norval,
What if you cut off the tops of the stands, welded smaller square tubing that just fit inside the others, and put the together and drill holes in them to make them adjustable? Just put grade 8 bolts thru to the height you needed. Just a thought.
Bernie
Old Sep 25, 2005 | 06:22 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Those look great I just have the regular jack stands that I use. I'm hoping for a lift once I get the new garage built
