Battery question...
Old Sep 26, 2005 | 12:57 PM
Wrencher's Avatar
Wrencher
Default Battery question...
Has anyone successfully relocated the battery to the back end of a C-3? I'm trying to improve the weight distribution on mine, and I want to put it on the passenger side somewhere as far back as it'll go. I can only remove so much weight from the front (that iron block and my fat **s are not going anywhere!), so in addition to removing the spare tire assembly, I'm looking at this. Any thoughts?
Hans
Old Sep 26, 2005 | 01:26 PM
big_G's Avatar
big_G
You might borrow some scales from a circle-track racer before you move the battery. The drive-train on our Vettes is off-set a couple of inches to the right already. This would lead me to believe that with a driver, the balance is probably close now.
Old Sep 26, 2005 | 05:13 PM
Wrencher's Avatar
Wrencher
If that's the case it would make it easier as I could use any part of that back area. Besides, I'm 6'2" 200lbs., so the engine would need to be WAY over to compensate...
Thanks.
To Battery question...
