80 headlight problem
Old Sep 27, 2005 | 07:55 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default 80 headlight problem
I am looking into buying an 80. The headlights are not working. Are these still the vacuum type or do they have a motor or what!??!?
Also, what is a common cause for them not to work? Is it expensive to fix?
Thanks in advance!
-Rick
Old Sep 27, 2005 | 08:33 AM
Crash80's Avatar
Crash80
They are vacuum animals on the 80. Typically there is some sort of vacuum leak that will cause them to default in the upright position. The '80 has about a mile and half of vacuum lines under the hood.
Old Sep 27, 2005 | 11:20 AM
texaswilkins's Avatar
texaswilkins
The vacuum hose kits aren't that expensive and they come with a diagram.
Bill
Old Sep 27, 2005 | 12:36 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Here's a link to the vacuum troubleshooting guide @ Corvette 101. Should give you an idea of what you're looking at. It could just be some hoses, or you might have to replace acutators or relays or the can...
http://209.183.231.72/corvette-101/vacuum.htm
Old Sep 27, 2005 | 01:00 PM
GTR1999's Avatar
GTR1999
Rick I wouldn't let that problem stop you from buying the car if everything else checks out.
Gary
Old Sep 27, 2005 | 02:18 PM
Chopper Larry's Avatar
Chopper Larry
I think a large percent of the time, it is the vacuum RELAYS that go bad.
cicch95's Avatar
cicch95
Thanks for the advice guys! appreciate it.
Old Sep 27, 2005 | 02:19 PM
cicch95's Avatar
cicch95
Gary
When r u going to ge tup here to RI for some cruising with us Gary!??!
Old Sep 27, 2005 | 02:40 PM
GTR1999's Avatar
GTR1999
Hey Rick,
I haven't been back to RI since last Xmas. My son now drives up to URI so I don't have to make the trips anymore. I'd like to get to that show you guys have every summer,hopefully next year
Is this your first C3?
Gary
Old Sep 27, 2005 | 09:06 PM
vabeachvette's Avatar
vabeachvette
I bought my 73 w/ a headlight problem, was the first thing I had to work on. My was an accumulator leak. I had replaced the headlight actuators that I thought might have been bad, so if yours turns out to be actuators send me a PM and I can work you a deal for them. Good luck.
Old Sep 28, 2005 | 07:22 AM
cicch95's Avatar
cicch95
Thanks for the info guys! It is apprciated.
VABEACH.....I'll drop you aline if that turns out to be the probem. Thanks.
To 80 headlight problem
